Not real sure if this is similar to what you want/need?
http://meci.com/Catalog/Item/b7ea9de...e-36b2266cfe9c
Dual Lilliput's 70NP/C/T
Syntax SV266AD KT266A
AMD Athlon XP 2000
Viking 256MB DDR
D-Link Wireless 802.11B
Seagate 120GB
OrbitMicro 250W DC/DC converter
SII Wireless Audio Link
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
"Geeks dont need girlfriends we can ping ourselves"
Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
i've done it......its pretty easy.....depeneding on the touchpad component you have. If its standard the wires match up the same as they would on a regular ps2 mouse. There are 4 wires, you can look at it and usually tell that the biggest one is (usually) ground, and the second biggest is power. The other two are data.....if you find the pinout of a PS2 mouse....you can can wire up the power and ground, and then you have a 50% chance of getting the two datas right, if your wrong, no harm done.....just swap the two datas......just make sure you get the power and ground right.
PC Components:
My work log
thats not a mousepad, thats the eraser tip mouseOriginally Posted by veedubya
PC Components:
My work log
I like to eraser tip better don't have to do anything just buy it plug it in to your mouse port and your done and its works great can't remember the last time I used my touch screen .
Cheap touchpads... is the thread discussing the laptop touchpad I did. The actual pinout is likely to be different than yours though. Post #9 has my quick description of methodology (nothing fancyOriginally Posted by Pokey
) which you might find helpful.
