have you either probed them with a multimeter and/or got a copy of the wiring diagram so you can figure out what kind of problems you face?
If they are on your column (not the wheel) then you may be able to solder lines to the switches and run them down your cowling to a gamepad and use something like steveg's control software or if its a 2 wire bus you can hook that inplace of a analogue joystick and use god_of_cpus software to set up keypresses for different resistances.
LinkBack URL
About LinkBacks
