Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 60
Thread: Thumb print car starter
  1. #41
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    Not sure if I understand you correctly, but if the thief removed the relay and shorted the wires would the fuel pump not run as normal? If so I don't think any security system could rely on a relay or two, the computer would need to be more integrated with the PCM or similar.
  2. #42
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    Quote Originally Posted by roadhog
    funny, vipers / compustars....etc....all rely on relays.....the starter immobilizers are simple relays. and if you install a transponder(remote start), you're asking for trouble. Now its as simple as bypassing that relay, and hotwiring a car like in the good 'ol days.
    people keep missunderstanding the method I explained. The feul like wire would never be cut (by the relay), until someone missed the security code. After this...its off. Removing the computer wont help, unless they find the relay connected to the feul line and bypass it. Disabling the computer before the relay cuts off the feul line would be a way to bypass it. But in this case, the theif would have to know its there. Once they attempt to start (without looking for the feul cuttoff relay, or disabling the computer) its too late.
    PC Components:
    My work log
  3. #43
    Dec 2004
    Maryland
    Quote Originally Posted by BoraXP
    wow first attempt at this was horribly scattered lets try this again:
    i was just giving em trouble thats all
    i wasnt taking anything serious
    get safe
    hack it up find out where unlock signal comes from
    throw that into a timer relay (when given power the relay holds circut for predetermind amount of time)
    this arms a pushbutton start
    then after 30 seconds it cancels the circut to the pushbutton start
    if the car is on it stays on
    if the car didnt start the start button wont work till fingerprint is done again...
    bla bla bla
    this method would require the fingerprint reader to be autonomous of the computer
    PC Components:
    My work log
  4. #44
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    yeah it is check the link
  5. #45
    Jun 2004
    Graham, WA
    couldnt you use a finger print scanner like the microsoft one, and then figure out what signal it sends out for the finger print and then make a lil board that would read the signal and trigger a relay thats hidden somewhere to turn on the fuel pump? This would eliminate a few problems first being price, second being reliant on the carputer, and third by hiding the relay somewhere no theif will ever find it unless they tow your car away and have the time to strip it to find out how it all works and even then prolly wont understand it
  6. #46
    Jul 2003
    its usb i believe
    the scanning is software based
    when/If i get my next car i will keep an eye out on ebay for a biometric safe and give my way a try
    i fully intend to keep the key to arm the car.
    and no matter what way we pick the car can be hotwired
  7. #47
    Jul 2005
    Hampshire UK
    Afaik the pc fingerprint readers are usb, requiring a usb host. A dedicated board sounds more reliable than a windows box...
    I take the point that other systems may well rely on relays. I suppose like just about any security, once you find the lock it's only a matter of time before it gets cracked. I guess the best defense is disguise... dummy circuitry, more relays etc etc.
  8. #48
    Jul 2005
    Hampshire UK
    UK fords have used transponder keys for some years now, without the transponder you're stuck. Not sure but I believe they go into the PCM, and I imagine that's more trouble to figure out than it's worth for a potential thief.
  9. #49
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    There are tow discussions going on. Security and Implementation and failsafe.
    Any security measure can be overcome, it is a matter of time and patience.
    Getting the system to work is easy, getting it to work 100 percent of the time is not.
    Michael
  10. #50
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Peoples
    What keeps it off? In order to keep a relay energized, it must have signal. According to your system, the computer somehow provides the signal. Easy, if the computer is on, BUT, if the computer is off, or removed, then what supplies the signal to the relay?
    Again, if they see the screen, and notice the need for a code, they will just rip out the computer. What will keepthe car from starting with out the computers signal to the relay.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 07:34 AM
  2. Car as Daemon
    By thecapitalizt in forum Linux
    Last Post: 08-01-2005, 10:27 PM
  3. Newbie Getting Started in Car PC's
    By ItsAdam1 in forum Newbie
    Last Post: 07-17-2005, 04:19 PM
  4. Replies: 7
    Last Post: 07-02-2005, 03:47 PM
  5. Trunk Popper into Car Starter
    By PatO in forum Hardware Development
    Last Post: 01-02-2005, 01:09 PM
