has been discused thousands of times.![]()
Siemans ID mouse, need I say more.
thanks, just been and read it but it went nowhere, well as far as trying use/buy custom hardware.
I still think the id mouse is the way, its cheap, available, and has windows software to interface to other programs.
That can work both ways etc if it can talk to other software, other software can talk to it, but I am not a windows programmer so over to the others.
Haven't done a search yet, but this project would be MUCH easier and more reliable if the thumb print device itself was programmable, so it wouldn't have to be connected to the computer to work. You could just hook it up to the computer when you need to program your thumbprint into it, then from there, it just triggers a relay whenever it sees your thumb.
Originally Posted by XxAndyxX
That is the problem, these need to have a computer booted and running to be of any use, which means anywhere from 30 to 60 seconds to start your car. And, if there is a computer problem, well then you won't be able to start your car with out some sort of back up plan.
But really, while perhaps no one has done it yet (which might be telling in and of itself) the idea has been talked about A LOT.
Michael
Yes I can see waiting for XP to boot before starting a problem.......
But once booted it would be a good trick, and I suppose thats it, its a trick not a feature.
Originally Posted by lez
How would the trick "go" or "work", Like, click your fob to turn off the alarm, walk to car door, open it,...then what. What are the steps int he trick?
Michael
rather then having it start the car, how about you disable a timed sequence for killing the feul supply. If the car is put into gear (a relay controller board could sense this) then it could start a 1 minute shutdown sequence. If you dont press your finger to the board and get identified, then the realy controller could cut off your feul supply. Also, if you wanted to disable this functionality, it would be as simple as disabling that program/computer from running. If a thief gets into your car he probably wont know you have a computer in there right away.
PC Components:
My work log
Originally Posted by Peoples
What if the computer fails to boot?
Michael
