Results 1 to 10 of 17
Thread: Problem Installing ATI Remote Wonder
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    I just got an AIT Remote Wonder from someone on here that I trust.
    When I got home, I proceeded to download the driver from the ATI website since the guy didn't give me a CD.
    When I try to install it, I get 3 error messages durring the install process.
    After clicking OK to each of the msgs, it then proceeds to tell me to reboot. I reboot, and the damn thing doesn't work.
    Here are the error messages I get. Any Ideas?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    System specs, OS would help
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by 0l33l
    Laptop in my sig.
    PIII 700MHz-m, 256MB RAM, 40GB HD
    WinXP PRo SP2
    Aug 2004
    Make sure your logged in as the admin and make sure you have the proper drivers doesn't look like the drivers are any good .
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I have had alot of problems with my Remote Wonder, mostly my own fault.
    First, do not even look at the reciever until you have installed the software. USB is not plug 'n play...
    Second, here's how I get everything to work once I screwed up:
    Uninstall anything to do with the Remote. This includes hunting through your registry for anything that might not have uninstalled.
    Download the software from ATI:https://support.ati.com/ics/support/...ge&folderID=27
    That one should work if you have the 'original' one.
    Restart. (Hell, restart again for good measure. It can't hurt, and it gives you a chance to get something to eat.)
    At this point you should have the little icon down in the corner for the remote. If you don't, kick it. Hard. Because at this point, I usually end up uninstalling it, and trying again. Its a real pain in the ***.
    If you do have the little icon, click on it. You should have the options screen. If you have this, you should be ok. Close the options screen.
    Only at this point, should you even consider plugging in the reciever.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    Make sure it's not for RemoteCtrl 2..
    Un-Install everything ....
    reinstall everything ......
    then and only then do you plug in the USB dongle... and NEVER EVER move it to a different USB port or hub.
    They are touchy, but work great ...
    Don
    EDIT: I guess I should have read the previous post
    Variable Bitrate viper24's Avatar
    Oct 2005
    Sacramento, CA
    i just did the same thing, i have remote wonder 1. i will put a file download on my server for ya, mac and pc versions (very hard to come by the mac version)... the link will be http://66.205.154.83/ati/
    gimme a sec to get it posted.
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Thanks! As soon as I have access to my car PC again, I'll let you know if it worked.
    Peace,
    Rafster
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    dead thead but wanted to say thanks kiltjim.
    Mine only took 3 installs
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Mine still doesn't work......
    Arggggghhhhh!!!!
    Peace,
    Rafster
  1. X10 remote and bluetooth problem
    By liquid_smoke in forum Input Devices
    Last Post: 02-27-2008, 06:51 PM
  2. RR with ATI Remote Wonder anyone?
    By Chita79 in forum Road Runner
    Last Post: 04-10-2006, 08:36 AM
  3. problem installing VGA on GBOX P4
    By nevide in forum General Hardware Discussion
    Last Post: 11-01-2005, 11:44 AM
  4. Replies: 9
    Last Post: 03-01-2005, 12:00 AM
  5. ATI Remote Wonder vs. Media Center remote
    By Don 944 LA in forum Input Devices
    Last Post: 11-28-2004, 08:41 PM
