It will be more vehicles supported. At this time I'll add Toyota/Honda/Lexus/Acura.Originally Posted by Luderboy
No aftermarket won't worl. OEM only.Originally Posted by dasaint80
Car pc integration with ease
Car mediacenter
Car mediacenter
Aftermarket Alpine, Pioneer, Kenwood, etc. HU won't work with this adpater?Originally Posted by jbors
USAspec just released their ipod adapter for the newer Hondas/Acuras (Includes 04-06TLs).
http://www.discountcarstereo.com/detail.aspx?ID=879
For NAVI & XM compatible, they recommend a Y cable that allows you to tap into the BUS. I believe this is the same way the music link adapter works. Unfortunately, this adapter does not display text. Maybe they are only able to read the commands on the bus, and don't have the propers chips/timing to write to the bus? Hopefully, you can figure out how to do both.
Anyway, hope this helps with your project. I'm still interested in beta testing with my 05 TL navi.
-TJ
Smart Playlists Plugin for RoadRunner
CarPC - 05 Acura TL Navi (pics soon)
Retired CarPC - 03 Infiniti Qx4
You will need Y cable only to pass bus data to XM/Nav since when you add CD changer interface it ends up the bus with the default cable. So the cable just splits the bus so other devices can use it as well.
Car mediacenter
As stated in the first post the adapter is for OEM Toyota/Honda makes. SorryOriginally Posted by jmbickham
Car mediacenter
Hi, i've seen your product before and I've just found this post about a Toyota adapter! From looking at your pictures it appears that the connector you use is the small block cd changer connector. My toyota is an 97 Jap-only model which has the big block 12-pin, row of 5 over row of 7 connector on the back of the h/u. Would your product still be able to work with my headunit- obviously i would have to remove the small block connector and rewire it for the back of my headunit? from what I have been able to find, it appears that the cd changer control is the same, it's just the connector block which toyota have changed.Originally Posted by jbors
Yes, the old connector is also supported. Don't worry.
Car mediacenter
My bad... I meant the Car to PC adapater in general (sorry if I should have made another thread).... but I think I just answered my own question... MBUS. Which/what brand(s) use MBUS?Originally Posted by jbors
MBus adapter compatible only with aftermarket Alpine xDM-xxx units. That's the only aftermarket device supported...
Car mediacenter
