Results 1 to 6 of 6
Thread: Keyboard Input Died ?????
    Apr 2002
    Houston, TX
    I was doing some configuration on the Carputer last night (out of the car) trying to get the Garmin 15L I just installed working.... It was being seen as a Mouse, I guess, and REALLY freaking out the system..... Mouse movement and clicks all over the place.... programs opening and closing.... etc.... I renamed the sermouse.sys file as sermouse.BAK.sys as recommended in a post here....
    The mouse freakage went away... then shortly after this (not sure exactly when) but definately after a reboot, the keyboard was dead. I tried a second keyboard, no success.....
    The NUM / CAPS / SCROLL locks lights do not come on, there is no keyboard in the Device manager, under Keyboard in Control Panel, there is nothing listed in the Hardware tab....
    I did notice when I plug in a keyboard with the system up, the lights (for the locks) blink once, but nothing more... no blinks during bootup....
    I am hoping it is not hardware related (the connector or circuitry on the m/b).... Is there a keyboard drive (for a regular old corded PS2 keyboard) that can be installed.... Maybe I removed the keyboard driver after I changed the sermouse.sys file by bo-bo...... I don't think I did but who knows....
    Any ideas
    Oh, I also did a System Restore to before this sermouse.sys stuff, but that didn't help..
    Aug 2004
    Ann Arbor, MI
    hey man, sorry to hear about your trouble with this. Not exactly sure how much help I will be but I could brainstorm with you a bit. First off, did you get your Garmin working with the steps you mentioned? I would check the BIOS. if your GPS took control of your PS/2 ports its possible that it may have disabled the other one. installing PS/2 support with the touchscreen drivers does this to the mouse port. It wouldn't be too far a strech to think that another device couldn't do the same to your keyboard port.
    I think its safe to say that its not your keyboard. And I would venture to say that your mobo hardware is fine too.
    I will do some searching and see what I can come up with. Worst case scenario you do a clean OS install, or at least switch to a USB keyboard solution... assuming your GPS is working now as-is.
    Apr 2002
    Houston, TX
    Ya know, I never got around to check the GPS.... Memory is poor, but once I renamed the sermouse.sys file the jumping cursor problem went away, but I didn't get to the point of looking for active GPS info going in...... The keyboard problems started soon to immediately after that.
    I was thinking about going to a USB keyboard, but the keyboard is only for setup in house.. after that I will use the touch screen for 99% of time and a mini-usb key'b for the other 1%.
    Might just have to go get a full size USB keyboard, but was hoping to fix the problem instead of working around it.....
    Also I don't know if the GPS really "took control" of the PS2 port, I didn't have a PS2 mouse attached.... only had Touch Screen and a USB wireless mouse... which were working fine beofre and after the key'b problem....
    But Thanks much for the thoughts.... I will mull them over some more and any additional you might have would be most appreciated.
    Apr 2002
    Houston, TX
    So does anybody have any ideas on this???
    Googling ain't yielding much..... I have found some references to not working once Windows is up and going, but still working in BIOS and boot up... I have no life in the keyboard at any time.....
    This also leads me to difficulty in reinstalling Windows XP.... My BIOS is 2nd choice to boot to CD, I can't get into BIOS to change cause I have no DEL key..... then even if I do I can't hit F8 to accept license.....
    I feel like I am stuck in a catch 22....
    Any ideas?
    Raw Wave
    Jun 2004
    On the beach
    Doesn't the keyboard even work in the BIOS?
    Oct 2006
    Yeah , ive had that problem on two of my comps, I reinstalled windows xp, then Linux , In a nutshell my keyboard port was dead, switched to usb havnt had a problem yet thats been almost a year, if you cant find another solution , I recommend going ahead and get the usb keyboard their pretty cheap these days
  1. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  2. HELP, Input Signal to AMP
    By Power_nisse in forum Car Audio
    Last Post: 06-22-2005, 12:35 PM
  3. Keyboard required????
    By futuresweets10 in forum Input Devices
    Last Post: 11-16-2004, 03:36 PM
  4. Sky navigator remote as keyboard??
    By rhinoofstockton in forum Input Devices
    Last Post: 11-13-2004, 08:18 PM
  5. Keyboard problem in skin
    By gyro in forum NeoCar Media Center
    Last Post: 11-12-2004, 07:13 PM
