Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Touchscreen drivers not resuming from standby
  1. #11
    Jan 2005
    UK
  2. #12
    Aug 2006
    Central PA
    I had a similar issue and a powered hub fixed my problem. It's $20 fix from walmart.
  3. #13
    Low Bitrate ajscomp372's Avatar
    Mar 2006
    Buffalo, NY
    Try going to touchkit.com and downloading the drivers there. I used them with two different touchscreens from different manufacturers, and they worked with both. They are very robust, and work after hibernation and resume.
  4. #14
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    yeah...
    are you using RR?
    and if you are... are you sure its not just resuming from hibernation with right clicking enabled?if you are using RR, try connecting a mouse and then right click before doing anything, then try using it...
    it could be a driver issue... thats what happend to me
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
  1. Lilliput touchscreen drivers
    By inaneninja in forum LCD/Display
    Last Post: 01-28-2009, 07:45 PM
  2. Anyone know how to manually remove touchscreen drivers?
    By Sonicxtacy02 in forum LCD/Display
    Last Post: 06-02-2005, 12:05 AM
  3. Via Epia M-900 Video Drivers Not working
    By mattdisaster in forum General Hardware Discussion
    Last Post: 01-06-2005, 11:33 AM
  4. Xenarc Touchscreen Drivers without XF86?
    By millec in forum Input Devices
    Last Post: 05-26-2004, 03:00 AM
  5. Lilliput touchscreen drivers HELP PLEASE
    By CDesigns in forum LCD/Display
    Last Post: 11-24-2003, 04:42 PM
