I messed with it today, and I can remove/reinstall the usb cable after resume then it will start working again, but sometimes that screws up my powermate.
After I re-installed my system with another SP-13000 motherboard, and a new hard drive (XP Pro, SP2), I installed both Win XP drivers off the Egalax site for my 8" Lilliput TS. both of them exhibit the same behavior, the work fine after a restart, but stop working after resuming from standby. The TS worked fine in my old setup. The only differences as far as the TS goes between installs, is I am now using a un-powered USB hub for all my devices in the front of the car (TS, Powermate, GPS antenna) Could this cause the problem? I've removed/re-installed both drivers with no change.
Originally Posted by Snootch
I'm guessing it could be the problem to your setup...
btw, what do you mean by screwing up your powermate?
Yesterday, as I plugged/unplugged the hub from the motherboard to get the touchscreen to work, the powermate quit working too. I went into device manager, and the powermate driver dissapeared. I had to re-install the driver to get it working again.Originally Posted by Cris
Try to put all USB 1.1 device together. Do not MIX 1.1 and 2.0.
Why not put the powermate on another port from the mobo or different hub?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Originally Posted by MatrixPC
I don't think the Powermate is 1.1, nor the TS. The GPS is I think 1.1...![]()
i noticed my TS drivers (and gps) dont work coming out of standby when i go into standby with GPS open... my gps and ts are both usb so I think perhaps there may be some relation.
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
