Results 11 to 20 of 25
Thread: Synaptics Touchpad TM41PUK324
  1. #11
    Apr 2006
    New Zealand
    If I had the equipment do to that, we wouldnt be talking My multimeter threw a wobbly while I was repairing a 3kva UPS, and today's a public holiday in NZ so there's no chance of getting a replacement. It's visual + brain matter for the time being, and as I said, I'm not willing to guinea pig this one. All I can offer at this point is my observations in the hope that someone else can prove/disprove them.
  2. #12
    Mar 2002
    Certainly don't go by colors, only stuff that is meant to be user-serviceable tend to follow any sort of standard. Wait until you can pick up a new multi-meter before attempting anything.
  3. #13
    Apr 2006
    New Zealand
    yeah, having serviced Compaq PC's for years I know not to trust their colour co-ordination
    OK, just picked up a cheapy $6 multimeter while my Fluke goes in for RMA, and I can get a circuit between pins 1 and 4, and between pins 4 and almost anywhere else on the ASIC (X and Y pins etc) which leads me to believe that pin4 (orange) may be +5v - going straight through the PCB to the touchpad where charge differential (caused by a finger) is picked up by the ASIC and translated into X and Y co-ordinates which are then pushed back across DATA and CLK.
    No circuit between 1 and 2, 1 and 3, 4 and 2 or 4 and 3. Only 1 and 4.
    So my current opinion is:
    Orange - +5v
    Red/Brown - DATA, CLK (unknown order)
    Black - GND
  4. #14
    Mar 2002
    Oh yeah. I just remembered these things are typically very fault tolerant. Most touchpads are figured out by just randomly connecting things and re-trying until they work.
  5. #15
    Apr 2006
    New Zealand
    when I picked up the cheapo multimeter I grabbed some stuff to throw together a breakout board, and I dug up a dead laptop mobo from work's recycling bin to donate a PS/2 port, so I'll be soldering that all up and testing it tonight (it's 4.30pm here) I'll let you all know the results. Hopefully it will be just as easy as swapping red and brown to sort out DATA from CLK
  6. #16
    Apr 2006
    New Zealand
    Bingo.
    It is in this order:
    Pin 4/Orange: +5v
    Pin 3/Brown: CLK
    Pin 2/Red: DATA
    Pin 1/Black: GND
  7. #17
    May 2006
    Hi
    I've also a Synaptics Touchpad TM41PUK324 (compaq e500). From a microsoft ps2 mouse, I've taken the male connector and it's wire .
    The microsoft mouse ps2 connector have 5pins
    yellow -> pin5
    white -> pin4
    orange -> pin1
    blue -> pin3
    black (this big black wire seems to be GND, correspond to the metal part located around the male connector)
    ps2 male connector -> Synaptics
    yellow -> brown
    white -> orange
    orange -> red
    blue -> black
    doesn't work (not detected by winxp)
    I also tried
    yellow -> brown
    white -> orange
    orange -> red
    big black -> black
    doesn't work
    Do I need some special drivers ??
    What's wrong?
    Apr 2006
    New Zealand
    Judging by the information you've given, the first guess was right.
    1 data Orange - Red
    2 (reserved)
    3 gnd Blue - Black
    4 +5v White - Orange
    5 clock Brown - Yellow
    6 (reserved)
    yellow -> brown
    white -> orange
    orange -> red
    blue -> black
    RE: The big black one - this is shielding, the touchpad should work without it, but if not you could try soldering this directly on to the touchpad. Peel back the black plastic covering and you'll notice a metal strip going around the circumference of the touchpad's PCB. That's a common ground, so solder on to that.
    Drivers - shouldnt need them really, windows should just treat it as a standard ps/2 device, and if not it should go through the motions of adding new hardware... have you tried on any other computers? Have you checked device manager? Have you tried installing any drivers you can find just to humour XP?
  9. #19
    Jun 2006
    France
    Hi
    Furstable I am de new member and my english is rusty
    I have also a synaptics touchpad from an armada e500. I surched to plug this one in a PS2 input. The only one help i found is this post. Thanks for your help but with the Whetu order it doesn't work. That's why I test condutivity between différents pins and points on the circuit.
    Colors of my touchpad pin are :
    Pin1 : Black
    Pin2 : Brown
    Pin3 : Red
    Pin4 : Orange
    And I found the good order :
    Pin1 / Black : +5V (I know black is funny for +VCC )
    Pin2 / Brown : DATA
    Pin3 / Red : CLK
    Pin4 / Orange : GND
    I tried this on two différents computers and it works very well. I used the connector and it's wire from an compaq mouse.
    For information, you can us the latest driver from synaptics with this touchpad and you can use scrolling fonctions.
  10. #20
    Maximum Bitrate DeltaFX's Avatar
    France
    Pics would help.
    Now Galileo is real. Muhahahahaha :p
  1. Laptop Touchpad to PS2
    By Paddymcc in forum Input Devices
    Last Post: 06-05-2009, 11:29 AM
  2. USB Touchpad into center console...
    By MacGuru in forum Fabrication
    Last Post: 07-31-2006, 10:58 PM
  3. Replies: 22
    Last Post: 06-01-2005, 10:10 PM
  4. Goldmine Touchpad Drivers
    By 0l33l in forum Input Devices
    Last Post: 11-08-2004, 09:57 PM
  5. molding in a touchpad
    By Cordell in forum Input Devices
    Last Post: 04-10-2003, 03:58 PM
