Results 1 to 9 of 9
Thread: touchscreen & com port?
    Constant Bitrate skeurton's Avatar
    Mar 2004
    newport news, va
    did a bit of searching on this issue, but haven't really come to any conclusions on it. so maybe someone can help me out with this one.
    i have a lilliput touchscreen and haven't been using it too much lately because it's been driving me crazy. it's almost nearly impossible to calibrate correctly, no matter what i try. but i discovered that if i disconnect the GPS receiver (which is also USB), the touchscreen works perfectly. plug it back in and the calibration goes to *****. so i'm wondering if it could be any of the following:
    1) com port issue: i installed the drivers for the GPS mouse BEFORE the drivers for the touchscreen. should i have done it the other way around?
    2) USB power issue: could it be that the touchscreen isn't getting enough power once the GPS mouse is plugged in?
    3) some other issue that i'm not aware of.
    any help would be greatly appreciated. i'd like to first try to troubleshoot the problem without having to spend any more money (i.e. physical hardware problem). thanks in advance.
    Mazda 6 Carputer
    elocine.net {NEW ALBUM AVAILABLE FOR FREE!!!}
    Feb 2006
    It sounds to me like your GPS driver is capable of working off USB also. I say that because it seems like your driver is sending info out to the USB devices “looking” for a GPS. It obviously finds the GPS on the com port but continues sending info out the USB or you wouldn’t continue to have the problem. I don’t know. I just took a stab in the dark. Try uninstalling your GPS driver but leave the GPS device plugged in. Then you would know it is related to the driver only.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    1) the order shoudlnt' matter
    2) could be, try to use a hub. but doesnt' sound like it, more like a conflict to me.
    3) conflicts are rare with usb, but they could happen. try to uninstall both devices in device manager. see if that helps
    Mar 2004
    newport news, va
    i've done quite a bit of research and troubleshooting in the past day or so, but nothing seems to work. it was working perfectly fine this morning, but now the touchscreen panel doesn't even respond at all anymore. windows still detects the usb controller, so i suspect it may be a problem with the TS panel itself. after all, it has been sitting in my car for two years now. i've already ordered a new one, so we'll see if that fixes it.
    Mazda 6 Carputer
    Jan 2006
    Arkansas
    Sounds out there -- Power flux issue? are you running @ your PSU's max and its having problems giving power out to your USB items?
    Jim
    2012 Honda Pilot (In Progress)
    2010 Honda Accord (After the Pilot)
    2008 Honda VTX1800N
    rad
    rad is offline
    Mar 2006
    Im having a similar issue. The pointer will just jump all over the place. I've tried every combination... of installing, reinstalling, com port selection... and it will work and the drivers will stick... till the next boot up. Im going to do some more research on the device IDs.
    MB: MII10000
    screen: lilliput
    GPS: Duleo
    Mar 2004
    newport news, va
    i'm pretty sure that it was the touchpanel on mine that went bad. i replaced the entire monitor with the newer lilliput and everything works perfectly. i had ordered a replacement touchpanel from digitalww, but it was cracked when i received it. still haven't been able to get in touch with armen about it, so i'm still waiting to get another one to see if that was really the problem.
    Mazda 6 Carputer
    May 2006
    Hi
    I've also a touchscreen & com problem with my innovatek 8'' tm-868 touchscreen. When I install drivers (downloaded from http://www.egalax.com.tw) http://www.egalax.com.tw/drivers/Win...4.0.2.1929.zip
    it freeze my winXP pro just after I've click continue installation without digitaly signed driver .... ... (ps2 driver not installed)
    I've tried several driver's version always the same problem.
    The touchkit software is installled but doesn't recognise my touchscreen.
    I've tried to install my touchscreen on my desktop and no problem, everything working fine.
    I think the problem comes from my sony vaio tr5mp, because it's doesn't have any physical com/ps2 port. My integrated bluetooth emulate a com port and also my gps mouse receiver which probably interfer with my touchscreen.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    you're probably getting a hardware config error. my my advice would be to uninstall all comports/blutooth adaptors etc and start again.
  1. Replies: 2
    Last Post: 09-07-2005, 03:03 AM
  2. Replies: 14
    Last Post: 08-15-2005, 07:27 PM
  3. Replies: 3
    Last Post: 07-11-2005, 06:23 PM
  4. 7" Lilliput for sale NO TOUCHSCREEN
    By CDesigns in forum Classified Archive
    Last Post: 05-24-2004, 10:47 PM
  5. Lilliput touchscreen woes/probs
    By Leddy in forum Input Devices
    Last Post: 05-15-2004, 09:42 PM
