Results 1 to 10 of 10
Thread: Inout Circuit Does anybody know of this
    Sep 2005
    InOut Circuit Does anybody know of this ARDUINO ?
    Hi I stumbled on this http://www.arduino.cc/en/
    Seems interesting as it's open source and available for every system Win, Mac and Linux
    Further they've got RS, USB and are in the process of releasing a BT unit
    Sounds nice I'm investing some time into it
    If someone can tell me some of his expereinces interests me highly
    PS Haven't found anything of it on the site, funny because it's USB and doesn't break the bank !!
    Jun 2005
    Michigan
    Not too bad. Gives you a programmer, compiler, bootloader, and C-like language for an Atmel uC. Language looks simple, so assuming the software works well, should allow rapid prototyping.
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
    Raw Wave lostreception's Avatar
    NY
    im no programmer but 30 bucks for an i/o board how can u go wrong
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Sep 2005
    the language looks easy enough, I wonder if we could use this as a USB relay driver?
    Jun 2005
    Michigan
    On the PC side, its kind of hard to tell how it will work. Looks like it can communicate to Flash, so I assume VB will handle it as well. On the hardware side its an Atmel chip, similar to a PIC. To run a relay will take a little extra hardware, but doesnt seem out of the question at all.
    Sep 2005
    I was thinking:
    wire transistors to the digital outputs, then have the transistor array drive the relays. I don't have a clue about the software
    Jun 2005
    Michigan
    Definately, the hardware will work. Just need someone with a little free time to buy one and see how easy it will be to interface with USB in realtime...
    Are you guys still looking for a usb I/O board? Once I finish up a few projects I'm working on I will look into it.
    I know there are new pics on the market that can handle usb comunications so I will look into those as they are relatively in expensive.
    Also on the site you linked to it looks like they are working on a usb model as well.
    Jun 2005
    Michigan
    PICs expensive? As long as you only want 5 at a time, any PIC is free
    There's been an old PIC16 on the market for a while with USB, but I've never really seen how its supported on the PC side. The hardware wouldnt be bad for me, but I just dont know how the drivers are handled to get it into VB or VC++.
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Thumbs up
    Hey everyone, I just picked one of these up, and it is to cool!!!!
    One really cool thing that the Arduino Board does is that you program it using a language similar to basic, then it is a standalone piece of equipment. It doesn’t have to be connected to the computer to process the code. This is one of the requirements that I wanted beyond a basic relay card. With this thing you program it and it processes the code on its own.
    The best part is that it is all open-source! The source code for the processor, schematics, and even the programming language are all available on the web site.
    Here is the pin-out from the Arduino web site “
    Starting clockwise from the top center:
    • Analog Reference pin (orange)
    • Digital Ground (light green)
    • Digital Pins 2-13 (green)
    • Digital Pins 0-1/Serial In/Out - TX/RX (dark green) - These pins cannot be used for digital i/o (digitalRead and digitalWrite) if you are also using serial communication (e.g. Serial.begin).
    • Reset Button - S1 (dark blue)
    • In-circuit Serial Programmer (blue-green)
    • Analog In Pins 0-5 (light blue)
    • Power and Ground Pins (power: orange, grounds: light orange)
    • External Power Supply In (9-12VDC) - X1 (pink)
    • Toggles External Power and USB Power (place jumper on two pins closest to desired supply) - SV1 (purple)
    • USB (used for uploading sketches to the board and for serial communication between the board and the computer; can be used to power the board) (yellow)
    I got my board from www.sparkfun.com for about $50 along with some other items. Check it out. :-)
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 04:43 PM
  2. Tank Circuit For Sale?
    By mattdisaster in forum Power Supplies
    Last Post: 03-14-2007, 07:07 PM
  3. Electronics people, help me with a custom circuit
    By Greenbuggy in forum Hardware Development
    Last Post: 03-07-2005, 08:53 PM
  4. Need help reading ring generator circuit
    By Crashless in forum Hardware Development
    Last Post: 02-21-2005, 06:19 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 04:00 PM
