Results 1 to 6 of 6
Thread: Rubber backed buttons and PCB pads
    Aug 2005
    My radio PCB has the type of buttons that if you push against them rubber on the back of the button contacts the PCB and they activate. I want to relocate my buttons to somewhere the PCB does not fit, so I need to put something else behind the buttons and find a way to wire it so it activates the pads onthe PCB.
    I am thinking I can solder extension wires onto the PCB where the button pads are, then buy some mini push switches to relocate behind the buttons. Will this work or am I missing something with how these PCB pad buttons work?
    Sorry if this is in the wrong section, seemed like the most appropriate.
    Low Bitrate hakhawk's Avatar
    Apr 2005
    newborough, VIC, AUS
    yep, just solder extension wires and new buttons of your choice as you said.
    the rubber pads are just a conductive carbon pad or something on them.
    THE NEW
    : www.lowagz.co.nr ::
    THE OLD
    :: www.hakhawk.co.nr ::
    Jan 2006
    Michigan
    The only time this wouldn't work for you is if the buttons were actually analog (like Xbox and PS2 controllers) they can sense how hard you press the button. They look the same as the buttons you are dealing with, but are made of a different material in a squishy convex(?) shape. The harder you press, the more surface area is covered and the less the resistance.
    But, I am just rambling, because it is unlikely you will encounter those types much in carpcs.
    Scott McDonnell
    Jun 2005
    Michigan
    There is another small possibility that may bite you later on. Those carbon-loaded rubber pads have a pretty high resistance, and if you use an off-the-shelf pushbutton it will likely be a lot lower. Depending on how they set the buttons up, this may allow too much current to flow through the switches and burn up the sensing circuit. It will most likely be fine, but if you're really concerned, try to measure the "on" resistance of the original switches and just match that using a serial resistor when you install the new push button.
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
    Low Bitrate MATRIXSHARK's Avatar
    Sep 2005
    Do yourself a favor and follow the cicuit traces. DON'T try and solder to where the old buttons actually are. Just follow the "flow" of current and complete the circuit somewhere that is easier to solder to.
    2000 Acura Integra Type-R
    Progress = 99% ---> Check it out:
    http://www.matrixshark.com/carputer.htm
    May 2006
    Perth, Australia
  1. 2003 Mercedes C-Sports Coupe
    By taylor192 in forum Worklogs
    Last Post: 04-10-2006, 09:37 AM
  2. Replies: 7
    Last Post: 02-05-2005, 07:41 AM
