Results 1 to 4 of 4
Thread: Girder Help! Separate Inputs from USB Touchscreen & PS/2 Mouse
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Exclamation Girder Help! Separate Inputs from USB Touchscreen & PS/2 Mouse
    Does anybody know how to separate between the Event LCLICK coming from a USB Touchscreen and the Event LCLICK coming from a PS/2 Mouse?
    I'm currently using Girder 3.3.4 and Mouse v3.0 Plugin.
    What I'm trying to do is use all of the PS/2 mouse's buttons (Left, Right, Middle, X1, & X2) as soft buttons, while still being able to use the touchscreen's regular point-to-click (and hold to right-click) function.
    If it's at all possible, or if anyone had tried developing a solution to that, please shere below.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Newbie wolfebaine's Avatar
    Dec 2005
    Etters, PA
    Get a serial mouse. It'll be alot easier.
    Apr 2005
    Quote Originally Posted by wolfebaine
    Great Idea! Except that I don't think they make a 5-button & analogly encoded scroll-wheel serial mice.
    This really got me thinking though... Is there a way to emulate the PS/2 mouse into a COM# port so that the computer can handle it differently?
    That way I'd be able to use a different Girder plug in (I think Igor's) that would handle COM Port Device behavior.
    Apr 2005
    In answer to my own question, I found the following solution dating back to 1996! Can anyone confirm this stuff actually works with newer mice?
    Maybe most of the modern mice have that "combined-mouse" feature the author is referring to?
    Quote Originally Posted by Kristjan Plaetzer
    A normal serial mouse can not be used on the PS/2 mouse port. Even the
    available "serial-to-PS/2" adapters do not help. The signals and the
    protocol is too different. Only a PS/2 mouse does work on a PS/2 port. By
    the way there are some kind of "combined-mice" just as Microsofts
    "Serial/Mouse Port Compatible Mouse 2.0" (Nr. 58264) and Logitechs MouseMan
    M-CJ13 and TrackMan T-CC2-9F. The owner of such a Logitech-mouse can use a
    Sub-D-plug. Here is the pin-mapping for such an adapter:
    Code:
           6 # 5                 1 2 3 4 5
          4     3                 6 7 8 9
           2   1
      PS/2           Sub-D-plug for Logitech
        1 -------------------- 9 (Data)
        3 -------------------- 5 (Gnd)
        4 -------------------- 8 (+5 V)
        5 -------------------- 1 (Clock)
    The diagram shows the view onto the contacts and not onto the soldering
    side. This special solution is only possible for those two Logitech-types,
    no other serial mouse is able to use the PS/2 signals.
    Kristjan Plaetzer
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 07:06 PM
  3. Integrate mouse into Pioneer touchscreen receiver?
    By rulouder22 in forum Input Devices
    Last Post: 10-01-2003, 12:38 PM
  4. Non-working touchscreen - USB Diagnostics tool?
    By GingerPrince in forum LCD/Display
    Last Post: 09-15-2003, 05:06 PM
  5. ps/2 touchscreen problem
    By Odie in forum LCD/Display
    Last Post: 02-20-2003, 06:27 PM
