Results 1 to 10 of 11
Thread: Rotatable monitor possible?
    Nov 2005
    Sonoma County, CA
    Is it possible to configure/hack a touchscreen monitor such that it can be rotated 90 degrees? Examples are PDA screens that have adjustable orientations depending on user need.
    I want to be able to use more vertical screen space for GPS orientation when driving, then change the monitor back for other uses. I want to get an 8" diag monitor based on cost, rather than a 10".
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    i'm not sure why you would want to change back and forth, but yes you can. the video card must be capable of this.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    There is some software that can rotate your screen.
    Nov 2005
    Sonoma County, CA
    Which software? I am using a Mac.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by daj100
    That peice of info would've helped if it was included in your first post
    Nov 2005
    Sonoma County, CA
    Yes, sorry--I had several distractions happen all at once.
    I am running a Mac ibook on OSX, BUT I also run Windows XP under Virtual PC, so any software for either OS could be used.
    Thanks.
    Jul 2004
    Berkeley, CA
    http://personalcomputing.portrait.co..._overview.html
    I guess you'll be using that, since OSX doesn't have any good GSP programs.
    Nov 2005
    Sonoma County, CA
    Thanks! I'll let you know what happens.
    Jul 2004
    Berkeley, CA
    BTW: There are probably some free utilities that do the same thing.
    Another program that comes to mind: powerstrip, but its not free.
    Nov 2005
    Sonoma County, CA
    I did a little more research--the Mac OSX has a semi-hidden control that will rotate the screen, though it may not always work well.
