Results 11 to 20 of 23
Thread: pda for datalogging & mp3 files?
  1. #11
    kgj
    kgj is offline
    Apr 2006
    the A!
    Quote Originally Posted by Genesisfactor
    You can shell out $150 for a PDA that will give you everythign you want. Axims are nice because you have dual card slots. Toshiba e7XX series are also great, plus have the bonues of Wifi at a cheap price. The best idea is to get an x50v, with VGA output, and you can display things on a screen
    Do any of these pda's have serial connection ports (or accept serially transmitted data) for data logging from my car's ECU? i think the OBD-I protocol is to transmit data serially. as i said earlier, i prefer to use a palm unit since i already have the accessories for it (cradle, cable & right-fitting connectors/adapters, etc.). however, i would definitely get another one if it offers all 3 basic things i need (datalog, mp3 player, able external output to another source)
    i noticed on the list of compatible units a "palm tungsten w". anyone familiar with this unit? i have looked on palm's webiste but they did not show the detail i need. i tried to compare it on pricegrabber too, but they don't even list the unit.
  2. #12
    Newbie prodigi's Avatar
    May 2006
    Philippines
    Thumbs up
    Quote Originally Posted by kgj
    i have 90 eclipse & a pda which i use for a datalogger. i have the mmcd software loaded in the pda (palm iiix) & i love it. recently though i have been rethinking my whole stereo & electronics setup. i was thinking of gettting rid of my multidisc cd-changer & getting a stereo receiver that plays mp3 files or an ipod music file via an external input. then i got to thinking why not swap out my pda too with one that can do both datalogging & play mp3 files? my goal is to have a pda with mmcd datalogger loaded on it that i could also plug into my (car) stereo receiver to listen to the stored mp3 files. is this do-able??
    Good idea. How about the Palm Tungsten W? It's a PDA phone with a built-in earphone plug and it still uses the standard HotSync cradle/cable from the Palm m500 series handhelds. It's also under the list of supported devices for the MMCd software. I just don't know if it supports MP3 playback. If it does, I'm going for the same set-up.
  3. #13
    Elsewhere
    Typically, PDAs don't have serial conenctions. You might find one with a USB connection, which is a serial connection, but you'd need a USB OBD cable. Realistically, I'd look into a bluetooth OPBD reader and a PDA with bluetooth capability (either built-in or available as an additional module). That might be the best solution.
    I believe that Palms Tungsten line is no longer made. That would explain why you're finding very little about those models.
    How about the Wiki?
  4. #14
    FLAC jbors's Avatar
    Nov 2003
    Most of the recent PDAs have serials. I'll name a few for you.
    Dell Axim x*
    HP iPaq hx*/rx*
    Palm Tungsten T3/T5/TX/Treo etc
    Hope this helps.
    Quote Originally Posted by DarquePervert
    Hmm I think it is little tough to say. Tugnsten's current model is TX, but they target to Treo 600/700 mostly these days. Those phones also have serial available through the Mutli Connector.
    Car pc integration with ease
    Car mediacenter
  5. #15
    kgj
    kgj is offline
    Apr 2006
    the A!
    Quote Originally Posted by prodigi
    i'm not sure about the m series, but i know the tunsten w (TW) will not fit my palm iiix cradle. http://www.pdastreet.com/forums/showthread.php?t=65651
    & from what i know it can support mp3 files, but there may be some other acessories needed to make it happen?
  6. #16
    kgj
    kgj is offline
    Apr 2006
    the A!
    thanks darque. i know what bluetooth is but not OPBD. what is that?
    yes its true the TW is no longer made, but it's not an issue obtaining it. i just got my palm iiix earlier this year off ebay & have been able to find info for it. i have been able to find info on the TW too, but not the specific info i was requesting. (at least not until recently )
  7. #17
    Elsewhere
    Quote Originally Posted by jbors
    So it's a serial port or a USB port through an add-on adapter?
    Good thing to know, although it's not anything I'd need.
    That would be a typo. It should be OBD.
    How about the Wiki?
  8. #18
    Mar 2006
    Portsmouth, UK
    Hi.
    I've used my Palm Tungsten T3 in the car for music playback before, and i know that it has both USB and serial communications.
    However, I think you'd get a little unstuck as you couldn't do both datalogging and music playback at the same time ( if that's what you wanted to do ) without some nasty hacking of code.... the palm's can only run one program at once as far as i'm concerned.
    Good luck with it though!
    Wolfsbane2k
    Fitting out a Skoda Octavia GLX.
    Progress [__________] (ie nothing yet!)
  9. #19
    FLAC jbors's Avatar
    Nov 2003
    Quote Originally Posted by Wolfsbane2k
    Not exaclty, PalmTunes and other music players can play in the background just fine on Palm. Even though blocking datalogging may have some side effects
    So I would also recommend Win/Lin based systems.
    Car mediacenter
  10. #20
    FLAC jbors's Avatar
    Nov 2003
    Actually they all have serial along with USB available on the connector at the bottom. If you need connectors there is a gomadic.com for it along with pinouts and stuff.
    Car mediacenter
  1. MP3 goes 5.1
    By camsgs3 in forum Software & Software Development
    Last Post: 01-14-2005, 04:43 PM
  2. WOL and Remote Control by PDA
    By NOS TANG in forum Wireless Communications
    Last Post: 01-08-2005, 03:44 PM
  3. MP3 CD has issues with MP3 HU
    By Antone in forum Car Audio
    Last Post: 01-04-2005, 02:32 PM
  4. In dash car MP3 CD Costs
    By mp3designer in forum Classified Archive
    Last Post: 02-06-2001, 03:23 PM
  5. Car MP3 Costs???
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-24-2001, 10:45 PM
