Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: pda for datalogging & mp3 files?
    kgj
    kgj is offline
    Apr 2006
    the A!
    i just found out & joined this site after being referred here from a fellow member on a car site. interesting stuff.
    i have 90 eclipse & a pda which i use for a datalogger. i have the mmcd software loaded in the pda (palm iiix) & i love it. recently though i have been rethinking my whole stereo & electronics setup. i was thinking of gettting rid of my multidisc cd-changer & getting a stereo receiver that plays mp3 files or an ipod music file via an external input. then i got to thinking why not swap out my pda too with one that can do both datalogging & play mp3 files? my goal is to have a pda with mmcd datalogger loaded on it that i could also plug into my (car) stereo receiver to listen to the stored mp3 files. is this do-able??
    i have researched pricegrabber (& similar sites) for pda's which also handle mp3 files. the list i saw from those searches did not match this list of pdas which can operate the datalogging software: http://mmcdlogger.sourceforge.net/#Palm%20Support
    so it appears the two can not coexist on one PDA, but i want to believe there does exist at least ONE pda that can host mmcd & mp3 files. is there a more recent, updated list? or does anyone know what i must do to make this work?? please help.
    kgj
    kgj is offline
    Apr 2006
    the A!
    does ANYone know about datalogging & mp3 playing capability with a pda??
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    Are you limited to using a Palm PDA? I have an iPaq (windows mobile) but most relatively recent PDAs (palm, windows, etc...) support playback of mp3 files.
    What pda do you have now? The only thing is song capacity will be limited by what type/size of card media storage you can use.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    kgj
    kgj is offline
    Apr 2006
    the A!
    Quote Originally Posted by nkotch
    i currently have a palm iiix. it has no mp3 capability. my hope would be to get a newer palm in the hope that i can still use some of my accessoreis, but it does not have to be one.
    my intent is to have a pda that can play as many or more songs as a 10-disc cd changer hence replacing its function. i don't know for what a comparable capacity would be, but assuming a typical cd will hold anywhere from 8 to maybe 15 songs per disk, that could result in ~150 songs. i figure if i have a pda that can store/play at least that many or close to, then i'm good to go.
    the only catch is, it has to be able to run dataloggin software. i use mmcd.
    http://sourceforge.net/project/showf...roup_id=114453
    forgive my inexperience in all of this, but it only recently dawned on my to rethink my audio setup so i am not at all familiar with ipods, ipaqs, nor mp3 capable pda's. so do you know of any that have both of these capabilities or have you ever used your pda as a datalogger?
    kgj
    kgj is offline
    Apr 2006
    the A!
    is what i'm looking for non existent?? aren't there pda's which also store mp3 files and can house datalogging software???
    Mar 2002
    Does the datalogging software you want to use have a forum? Perhaps checking there to see which newer Palm models can work with it would be better than checking here.
    Also, you may want to try to find a different datalogging software. "data logging Windows CE" yeilded alot of search results on Google, and nearly all Windows CE/Windows Mobile PDAs can play MP3s and videos. I'm not very familiar with data logging, so you'll have to search through and find what you need.
    kgj
    kgj is offline
    Apr 2006
    the A!
    [QUOTE=tom61]Does the datalogging software you want to use have a forum? Perhaps checking there to see which newer Palm models can work with it would be better than checking here.
    ...{/QUOTE]
    lol! actually there is forum for the datalogging software & someone on there specifically suggested that i come to THIS site! go figure.
    i prefer to use the mmcd software because i'm familiar with it, its freeware & it works well with my car.
    but, that is only half of the concern. i also want to know if there are pda's that have mp3 capability that can connect to a car stereo receiver and function similar to a multi disk changer. it seems there are car receivers that have aux inputs or external RCA connectors for this type of purpose, but i'm not sure how they work. will the receiver display info & offer control of the mpa player (or PDA) sort of like how it does with cd changer controls? or is the control done strictly from the pda & the receiver has no controller function & displays no info about the mp3 file being played?
    anyone familiar with that?
    Dec 2005
    FL
    I mentioned above that pretty much any PDA you buy now will support playback of mp3 files. The early palms may not, but just about all the ones you can get now either have a builtin media player or you can install any number of 3rd party ones. I think you need to check and see if you can find a newer palm model that runs that datalog software, and then go to Palm's website or do a google on the model and see if it supports playback of mp3.
    It'll be a pretty basic setup, the audio output (headphone jack) of the PDA will just plug into the AUX input of your head unit like you said. You'll have to control the music from the PDA though, as far as I know there's no head unit that'll control a PDA that's hooked up to it... too many different types and different software.
    Nick
    kgj
    kgj is offline
    Apr 2006
    the A!
    thanks nkotch. at least now i have a better idea of how/where the pda should be located in terms of accessing the music on it & being able to see it easily if i have to acess functions on it to control music playing.
    i'll check palm website again or ask them about using the external connections on their recent models. you see tmy car uses obd-i & the current cable i have uses a serial connector & converter which then connects to the palm's external port. i think it's a propietary configuration. it's not a serial bus nor USB port. i believe most of the recent models are using usb. i do not know of any cable that would work for connecting to my obd-1 connector.
    hopefully something is out there...
    & yes, you did state that earlier about pda's having mp3 capability.
    Mar 2005
    NY
    You can shell out $150 for a PDA that will give you everythign you want. Axims are nice because you have dual card slots. Toshiba e7XX series are also great, plus have the bonues of Wifi at a cheap price. The best idea is to get an x50v, with VGA output, and you can display things on a screen
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  1. MP3 goes 5.1
    By camsgs3 in forum Software & Software Development
    Last Post: 01-14-2005, 05:43 PM
  2. WOL and Remote Control by PDA
    By NOS TANG in forum Wireless Communications
    Last Post: 01-08-2005, 04:44 PM
  3. MP3 CD has issues with MP3 HU
    By Antone in forum Car Audio
    Last Post: 01-04-2005, 03:32 PM
  4. In dash car MP3 CD Costs
    By mp3designer in forum Classified Archive
    Last Post: 02-06-2001, 04:23 PM
  5. Car MP3 Costs???
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-24-2001, 11:45 PM
