Results 1 to 10 of 20
Thread: lilliput 7" driver not recognize
    May 2006
    has anyone ran into this problem...i had install lilliput ts, and it was working before, now it doesn't work. i'm running winxp pro (sp2) and loaded the latest driver from egalax.com for the touchscreen, and windows still gives me a message USB Device not recognize. I have plugged the usb part of lilliput screen to a different usb port and still comes up with the "usb not recognize" error message.... can anyone helppp thanks,
    Registered User
    The drivers that shipped with the monitors could be the problem, uninstall them and get an updated one from here
    May 2006
    okay, i will try this, thanks....
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    yeah, the updated drivers work, the oines i got w/ the lilli made it less compatable than the plug and play one on windows
    update it, and it will work perfectly
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    May 2006
    still not working
    i've downloaded the latest driver for my ts(lilliput 7") from http://www.egalax.com.tw/eg/drivers.htm and still not working...any ideas....thanks for the response...
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I am having the same exact issue. Was working fine when I had the carputer in the front for testing. Then disconnected everything and moved the carputer to under the seat and I started getting that message. I will try the new drivers (above posts) but what else could be wrong? The controller? HELP!
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    Dec 2004
    Bay Area, CA
    Need to get this on top.
    May 2006
    I am having the same issue. I have tried downloading the latest drivers from a few different sites, and none of them seem to be recogniized as the proper driver
    Dec 2004
    Bay Area, CA
    I am leaning towards a bad contoller but no one has been able to tell me if there is a way to test it. I really don't want to take the dash apart, then take the screen apart and replace the controller only to find out it was not the problem.
    May 2006
    mine is new, just manufactured in april, and am still having problems installing the drivers, have been playing with it all day
  1. Replies: 2
    Last Post: 07-22-2005, 02:17 AM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  3. FS: Taken Apart Lilliput 7" VGA TS
    By djXternal in forum Classified Archive
    Last Post: 02-16-2005, 06:30 PM
  4. lilliput driver error, wtf
    By bobthebaker in forum LCD/Display
    Last Post: 01-12-2005, 02:25 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
