Results 1 to 10 of 12
Thread: WTF..touch function keeps freezing
    Apr 2006
    after about 3mins of leaving it still, itll freeze on me...then id have to restart the computer to get it to work again or disable/enable device to get it to work....anyone has this problem or know how to fix it?
    it works fine if im constantly using it, but leaving it still itll freeze regardless of applications running
    and BTW new copy of windows XP installed and no other programs except lilliput
    Elsewhere
    Check the properties and make certain that it's not set to turn off hte device to save power. I've seen this option on a lot of devices and I absolutely hate it.
    That may or may not be your problem, but it's certainly worth a shot.
    How about the Wiki?
    Apr 2006
    ahh..got my hopes up..but that wasnt the problem...
    Apr 2006
    anyone?
    Nov 2006
    Romania
    mine did that too.
    i found out that using a shorter usb cable everything works perfect.
    initial i had a 6 meters long usb cable...
    My second Subaru skin
    Full screenshots second skin
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
    Mar 2004
    mine does that too, but I havn't figured out the problem yet
    Mar 2004
    well, I thought I had fixed the problem by reinstalling windows and turning off winxp's power management of the USB devices.
    I took a 3 hour drive without a problem, and then a few days later, 15 minutes into driving the touch screen froze. I had regular mouse that I plugged, and went into device manager. Apparently, the touch screen became an "Unkown Device" under USB devices. Disabling and renabling (which required a reboot) fixed it.
    Anyone know why it would do this? I'm using TinyXP rev05 with XP embedded and havent had a problem otherwise
    Aug 2006
    Mine does something similar.
    Might be a long shot but see if the usb plugs move when they are pluged in. I have a motorised screen that isn't properly secured (because its moving soon). Whenever I go over speed bumps... the touch screen wont work.
    I might try fabricating some sort of fastener or something similar to the plug used for the monitor.
    Mar 2004
    Quote Originally Posted by Night Crawler View Post
    I was wondering about that, but I doubt it since it's in there pretty good a simple reboot fixes the problem.
    Aug 2006
    I thought that at first, because all I have to do is reboot mine. I started playing around with the wires and noticed a bit of movement in the usb plugs. Only a tiny ammount though. Tried to do something on the screen after wiggling the usb plug and nothing happens.
    Worth a nosey
  1. Lilliput 7" (first model) touch function dead
    By holistic in forum LCD/Display
    Last Post: 09-28-2005, 02:27 AM
  2. Touch screen not worky worky (T-View 7")
    By deetap in forum LCD/Display
    Last Post: 08-22-2005, 05:44 PM
  3. Replies: 3
    Last Post: 08-18-2005, 01:03 PM
  4. dual mouse cursers for touch screen
    By beaverpants in forum Input Devices
    Last Post: 06-21-2004, 03:02 AM
  5. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
