Results 1 to 10 of 10
Thread: Lilliput touchscreen acting wierd
    Jul 2006
    Sin City
    I have a 7" Lilliput 619GL-70NP/C/T. While using the touchscreen, I noticed that I cant access the outer edges and mouse pointer only appears in the correct spot when I touch the screen in the middle area. If I try to touch it in other areas the pointer is off by almost a half inch. I was wondering if this was a driver issue, or if this was the way the Lilliput's touchscreen really worked? Thanks for any help.
    Nov 2005
    Have you run calibration?
    Maximum Bitrate pepsibobby's Avatar
    Dec 2005
    Kaiserslautern Germany
    mine does that if i use the flat part of my finger, try using the nail, its more precise. thats what i have been doing. Yes i ran calibration and no difference. good luck.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
    Jul 2006
    Sin City
    I've run the calibration and still no luck. It does it whether I use the stylus or my finger.
    Jan 2006
    dont know if you fixed this yet but its the drivers, 100% sure on this, i had the same problem, dont use the drviers that came with the unit as they are rubbish, search the net for older drivers and try them.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    wouldnt be so sure its the drivers, these touchscreens are known for going bad. I had to replace mine after a year, the left side just stopped responding to the finger/stylus. Tried recalibrating, tried new drivers.
    PC Components:
    My work log
    FLAC -zip-'s Avatar
    Ontario/Canada
    I get this in the winter as the screen is warm but the overlay is colder which makes a gap between the two, causing improper touch points and the mouse pointer is half an inch off to where I touch the screen.
    There are a lot of problems with a lilli touch screen overlay, some just stop working. You may need to purchase a new one.
    Sound Stage
    Eclipse|MTX|Infinity
    Aug 2006
    Any luck?
    Hello
    I have the same issue with my touch screen on Xandros GNU/Linux. Works fine in Microsoft Windows XP so its not a hardware issue.
    My X and Y were inverted originally but thats now fixed by loading the module as:
    modprobe touchkitusb swap_xy
    I have tried running various alignment programs but the mouse will not show in the relevant box!
    Have you had any luck?
    Jason
    Corrilan IT Consultancy Ltd
    http://www.corrilan.com
    01375 403508
    enquiries@corrilan.com
    Jul 2006
    i have just got my 8" lilliput and i had this problem.
    i ran the 4 point tocuh and nothiung happened so i ran the 25 point touch and its perfect now
    Aug 2006
    25 point on Linux?
    Hiya
    Did you do this on GNU/Linux or Microsoft Windows?
    If on GNU/Linux, where did you obtain the utility from?
    Jason
    01375 403508
  1. Replies: 1
    Last Post: 01-31-2005, 12:35 PM
  2. Replies: 0
    Last Post: 01-25-2005, 12:55 AM
  3. For Sale: Touchscreen from Lilliput 8" XGA display
    By Little-Acorn in forum Classified Archive
    Last Post: 12-30-2004, 11:19 PM
  4. Replies: 1
    Last Post: 12-21-2004, 09:25 PM
