Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Girder!
  1. #11
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    winlirc is usually used with girder.. you can use it alone there are many apps that can read codes from winlirc directly..there is a plugin for winamp also...by using that you can control winamp by winlirc only.. girder is more powerful though to control apps
    check this thread out it has everything
    Steering-Wheel Controller
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by GreenBeast
    it keeps picking up button presses as the same code
    this is on various devices, i added 3 different media PCs to my harmony remote ad tried 2 different dvd players, on all of them several buttons are the same
    i.e. ff and play, play/pause/stop, skip back and skip forward
    Try changing plugin priority level in igor config to 8 (I think default is 7 )
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    Jun 2005
    Kent, England
    winlirc keeps telling me it failed to initialize and would i like to change the config, that would be fine if i knew what any of it meant
    Matrix - i've got it on 8 now but no change
    i'm going insane!
  4. #14
    Apr 2006
    Greece
    winlirc always display that msg first time..change your com port to the correct one and then press "learn" so winlirc can learn your remote.. the learning process is quite guided.. although some remotes are very dificult.. what are you using for a remote?
    EDIT: maybe you can also find a config file ready in here so you will not have to go through the learning process. just press browse and load the file
    http://lirc.sourceforge.net/remotes/
  5. #15
    Jun 2005
    Kent, England
    winlirc doesn't show any response from my remote yet i know the remote and receiver work because girder receives signals
    the remote is a logitech harmony, its a universal remote and so i've been using various devices programmed into it for my commands
  6. #16
    Apr 2006
    Greece
    try pressing RAW CODES and see if it receives anything.. in raw it sould receive everything and anything even if it does not understant it correctly.. if you don't get anything in raw codes then I think your serial receiver is propably not compatible with winlirc..
  1. Girder stops working when RR is launched
    By BlackStealth in forum Road Runner
    Last Post: 09-07-2006, 07:35 PM
  2. Creative Infra Remote On Girder
    By mick0uziel in forum Input Devices
    Last Post: 07-27-2005, 10:43 PM
  3. Replies: 7
    Last Post: 03-11-2005, 12:36 PM
  4. Replies: 7
    Last Post: 02-26-2005, 06:09 AM
  5. Frodoplayer and Girder
    By leenas in forum FrodoPlayer
    Last Post: 04-30-2004, 11:42 PM
