Sensile feedback?Originally Posted by 0l33l
Looks like you've been busy around here, I'm glad to be back =P
Measure the output of the charger they provided both without a load and with. Chances are it is closer to 5V anyway unloaded. If it is more than 5V, you could probalby use the USB 5V with no problem. Then mount a big board the size of a keyboard to your dash to provide the flat spot. That should look good.Originally Posted by Philhop
~Jimmy
CarPC install is starting to come along again...
Thanks jimmy ill give that a go
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
If it does really need 4.3V then just use a rectifier diode to drop the 5V to ~4.3V.Originally Posted by Philhop
Dont mind what the others think. If it works well for you then thats all that matters.
Yeh... I'm still hereOriginally Posted by Grayscale
Now... were's the match to your custom user title![]()
