Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: USB Keyboard encoder - Interested ?
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by gagan512
    making you own PCB is really easy if you have a laser printer, and some patience. google a little and you'll find several links on how to do it yourself. i've been able to do very fine traces of upto 1mil. of course, once its in mass production i'll be sending it out to a fab
    by laser printer, do you mean inkjet or laser kind of laser, or laser as something by Universal Laser, a laser cutter/rasterer? I have both, so curious!
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Jun 2006
    Seattle
    Quote Originally Posted by 2k1Toaster
    chk out this link to start off with
    http://www.fullnet.com/u/tomg/gooteepc.htm
    http://www.wd5gnr.com/pcb.htm
    http://www.qsl.net/ve2emm/pcb/pcb2e.html
  3. #13
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    he means something like a hp4l etc.
    Its called toner transfer , a novel way to maknig pcb's and one I have used, to some success.
    Their is a homemade pcb yahoo group, were looking at direct inkjet printing and its 'working' if used with the right inks.
    Easiest toner transfer is to print (mirror the image) with the laser printer onto some glossy paper, the kind used for flyers(junk mail) or some photo papers(harder).
    Then you iron it on, dont smudge, get it hot, dont steam, dont even use a staeam iron the holes cause dropout etc.
    That gets the toner on the board, then etch.
    http://groups.yahoo.com/group/Homebrew_PCBs
    Lez, more widely known as flez1966
  4. #14
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I use lazer/copier machine and iron transfer method with "Staples Picture" paper. The result is perfect everytime.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #15
    Jun 2006
    Seattle
    Quote Originally Posted by MatrixPC
    yep, i use the exact same paper.
  6. #16
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    im ... interested .... so this device is recognised by windows as another keyboard device, and it sends the OS input, from 1 to 32 buttons you wire to the board, and then in the os you use them how? i think this could prove VERY usefull, if i understand how the os (read windows ) will use this decive
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
  7. #17
    Newbie ReverendR's Avatar
    Mar 2005
    SoCal
    I realize that this info comes a little late, but these sorts of keyboard interface boards are used by home arcade machine builders. You can get them from
    http://www.thrustvector.com/
    I think the Afterburner is the one that TeaVirus used in the cabinet I helped him build.
    But there's also these two
    http://groovygamegear.com/webstore/i...roducts_id=199
    http://www.ultimarc.com/ipac1.html
    You hook up switches to the terminal blocks and then tell the board that that switch = 'A'. Whenever that switch is closed the board tells the computer that the 'A' key has been pushed.
    The first casualty in any engagement is the Plan.
  8. #18
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by ReverendR
    the ipac boards also have software that will let you assign the inputs to any key press you need. I have one and it's a nice product.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  9. #19
    Jun 2006
    Seattle
    Quote Originally Posted by red_parchel
    So windows detects this as a usb keyboard. the only difference being, this has lesser keys.
    You wire a switch/button to one of the connectors, which is for eg. the key "B".
    Now lets say you setup global shortcuts in winamp to do 'next track' when 'B' is pressed... and i think you figured out the rest.
    similarly, you can use it for volume control, media control, shortcut keys etc..
    Its basically just a keyboard, just one that takes up no space, and on which you put your own buttons
  10. #20
    Oct 2004
    NY
    almost any usb keyboard already has a board like this that can be used... the big difference I see with yours is the pinout connections for keys, instead of say a ribbon cable... I've used boards like this straight out of $10 keyboards though.., yours is easier to implement
  1. Replies: 18
    Last Post: 07-26-2006, 10:50 AM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. FS: EL-610 USB illuminated Keyboard
    By Defiler in forum Classified Archive
    Last Post: 07-11-2005, 08:04 AM
  5. Fellowes USB Foldable Stowaway Keyboard...
    By Defiler in forum Input Devices
    Last Post: 10-19-2003, 09:55 AM
