i jusr relised this should go to hardware hacks sorry
ok i got an old ps2 keyboard and want to wire it to where i can have only one button on a cord to use as the number 0 key. can i do it how do i do it
nvm started cutting away plastic circuit bored worked with half cut off cut to much doent work anymore so can a mod close this
Is the circuit board still intact? You can emulate pressing a button with some TTL chips, but if going that route just chop off everything except for the cord!
Should be pretty easy.
1.9in x 2.9in -- 47mm x 73mm
i got the green circuit board that is hard where all the wires go to how do i do what your saying with it. i destroyed the printed circuit boards
