Results 1 to 6 of 6
Thread: DVD-ROM Power issue
    Newbie linkyone's Avatar
    Apr 2005
    Italy
    DVD-ROM Power issue
    I have a DVD Rom that doesnt want to spin up and operate. It is connected to a usb 2.0 hub in the dash. I am powering the hub from the psu. now the hub works fine (bluetooth, gps, keyboard) but when i plug in the DVD-rom it never really spins up all the way. it only gets so fast then stops and starts again. the dvd-rom is connected to the hub with one usb cable and the power for the drive is coming from the same wire (+5) connected to the PSU for the USB hub. i have pulled the dvd rom from the car and connected to a wall outlet (using the AC\DC converter provided) and it spins up just fine. now clearly i have a power issue (current related) but i dont know where to start. I can only guess my next move is to purchase a 12 to 5 volt regulator rated at 3 amps (same as the AC\DC converter) and try that. The PSU (m1-atx) is rated at 10A for the 5V rail and i dont think i am over that limit. I have only a bluetooth dongle, gps, a mini keyboard, and occasionally a flash drive connected. Any suggestions?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Mar 2006
    Colorado, but Canadian!
    Or just get another powered hub. USB can only provide 500mA total.
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2005
    Italy
    binary - yea thats the same one i was looking at. i tried building one out of some ICs (7805 5 volt regulators) but they just got hot. ill order one today
    2K1Toaster - Do you think that would work when the DVD-Rom drive needs 2.5 Amps to spin up?
    Mar 2006
    Quote Originally Posted by linkyone View Post
    What the hell kind of innefficient drive is that?! Laptop or Desktop drive?
    Apr 2005
    Italy
    Quote Originally Posted by 2k1Toaster View Post
    Its a Lacie laptop DVD-DL R/RW in an external usb 2 case. Yea, i didnt think it would be this power hungry when i bought it, boy was i wrong! I just ordered the 5 volt, 3 Amp regulator, actually i bought 2, one for my hub as well. My car pc (where my 5V originates) and the hub (in the dash) are about 20 ft apart (wire length) so i think i am dropping some power across that kind of length. Ill install these regulators and see if anything improves.
  1. Need help with Network DVD rom access
    By inniss777 in forum General Hardware Discussion
    Last Post: 07-19-2006, 07:58 AM
  2. WTB - Slim DVD ROM drive
    By Zebelkhan in forum Classified Archive
    Last Post: 04-20-2006, 02:04 PM
  3. wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
    By mattress in forum General Hardware Discussion
    Last Post: 04-05-2005, 07:15 PM
  4. Curious DVD power problem...
    By MC_Stoo in forum Power Supplies
    Last Post: 03-30-2005, 06:27 PM
  5. Tview power on issue
    By neon_eddy in forum LCD/Display
    Last Post: 01-10-2005, 11:49 AM
