Results 1 to 10 of 10
Thread: Building USB receiver?
    Mar 2004
    I have found the infiniti navi control (buttons + joystick) http://autonet.ca/Spotlight/TestDriv...ure15292-S.jpg
    It has a 7 pin connector. What would I need to convert this to usb or serial?
    May 2004
    NY State USA
    If this is possible, you probally will have to take the serial route.
    Can you think of any way to figure out what each pin does? Where do they lead to? Is that screen in the pic hooked to this in any way?
    Try hooking up a multimeter (set to condinuity) to each pin and a ground, and pressing each button to see if it jumps. If you can work out some sort of pattern with this, you may be able to use a digitol input card.
    New car means time for a new carputer.
    Planing.
    Mar 2004
    The screen is not hooked up, it has nothing to do with the buttons.
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by hoodlum View Post
    Since it looks like it has 11 buttons and 4 or 8 joystick directions it might be binary coded (Power, Ground and 5 Data lines - which would be good for 32 buttons).
    If that's true, you could use the ccStick to wire it up to the USB.
    Skinning to go... VisualDesigner2!
    Mar 2004
    11 buttons, 8 directions. no idea about anything else.... any ideas how to check?
    Mar 2004
    Munich, Germany
    Measure the 7 pin connector (coming from the car) for supply (+5V or +12V) and ground first. Then apply the voltage needed to those pins on the buttons panel and measure the signals coming from the panel when you press a button.
    Or, if you're not equipped to do so, ask the friendly car dealer near you
    Mar 2004
    Quote Originally Posted by zorro View Post
    Can't do that... the navi unit didnt come with the car, so i cant do that.
    Mar 2004
    Munich, Germany
    Well, then you better ask someone who has a wiring diagram for this unit otherwise you may f**k it up by applying unexpected voltages to it.
    Mar 2004
    would it say the voltage anywhere on the board?
    Mar 2004
    Munich, Germany
    Unlikely. Do you have a photo of the board? If so, post it (top and bottom layer).
  1. Holux GM-213 USB GPS Receiver, Good?
    By girbot in forum GPS
    Last Post: 04-24-2006, 12:35 AM
  2. F/S: Linksys Wireless G USB Receiver with moded Antenna
    By LESLIEx317537 in forum Classified Archive
    Last Post: 11-19-2005, 08:56 PM
  3. F/S Keypower DC-DC 250Watt, GPS receiver, and USB audio
    By Santa Cruz in forum Classified Archive
    Last Post: 06-08-2005, 01:44 AM
  4. Earthmate GPS Receiver USB
    By sesshoumaru562 in forum Classified Archive
    Last Post: 08-25-2004, 12:36 PM
  5. WTB: GPS receiver (USB)
    By Mastero in forum Classified Archive
    Last Post: 06-18-2004, 12:25 PM
