Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 5-Wire Resistive Touch Panel?
  1. #11
    Mar 2004
    i need to find a touchscreen with max size of 164x105mm... I cant finsh this project without it.
  2. #12
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by hoodlum View Post
    i've already told you where to look. why don't you go out and make some enquiries because no-one is going to go do them for you. Custom sized panels are not something people have lying around. I have already measured a xeanarc one for you and shown that it is suitable for you min dimensions and you dont even have the manners to say please and thank you!
  3. #13
    Mar 2004
    thank you. panel area is 170x106 but there is obviosuly a border. if you check the specs of the xenarc viewable area then i am pretty sure it is quoted as about 155x90 if i remember rightly.
    there is no boarder you can cut. its wires, how can you cut it.
  4. #14
    Mar 2004
    Bristol
    eh?
    1. i told you the Xenarc was 155x90 above
    2. you said the min area you needed was 154x90 which means that is just okay.
    3. who said anything about cutting anything? you cant cut your touch panel and why would you want to?
  5. #15
    Mar 2004
    i have xenarc, and its 170x105. it wont fit into the housing. the Viewable area will work, but the overal size wont.
  6. #16
    Mar 2004
    Bristol
    mod the housing then. dont trim the touch panel.
  7. #17
    Mar 2004
    Bristol
    a lilliput panel migth be slightly smaller or try contacting digitalww.com as they have some touch panels.
  8. #18
    Mar 2004
    1) i cant mod the housing, no room to go.
    2) i talked to armen, he doesnt have the size i need.
  9. #19
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Good luck finding a 5 wire panel that small.
    Here is a page of panels : http://www.review-displays.co.uk/amt_resproducts.asp
    Closest to your size spec is 166x100 external, 155x88 active area.
  10. #20
    Mar 2004
    Bristol
    Quote Originally Posted by Rob Withey View Post
    cool store.
  1. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 05:20 PM
  2. touchscreen panel controller wire of lilliput
    By ove1kenove in forum LCD/Display
    Last Post: 06-25-2005, 03:43 PM
  3. New Lilliput Touch Panel install have question
    By PHiLiSO in forum LCD/Display
    Last Post: 08-04-2004, 03:18 AM
  4. 3M Touch panel?
    By Sh0cker in forum Input Devices
    Last Post: 11-25-2003, 11:43 PM
