Results 1 to 10 of 20
Thread: 5-Wire Resistive Touch Panel?
    Mar 2004
    I am looking for max size of 165 x 105mm with viewable size not smaller then 154 x 90mm. Would anyone have anything in mind for me? 5-wire is the best, correct?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    sounds like the stock 7" xenarc touch panel to me.
    Xenarc Direct sell them. Dont forget to get a 5-wire controller
    Mar 2004
    Quote Originally Posted by Scouse Monkey View Post
    I dont think so, its bigger then my required size. Measure it, if you have one.
    Mar 2004
    What is the difference between 4 wire, and 5?
    Mar 2004
    Bristol
    Quote Originally Posted by hoodlum View Post
    yes sir, of course sir anything else sir?
    Mar 2004
    Bristol
    1 wire!
    no no seriously it is!
    ok i will be serious. Yes there is an extra wire and the touch panels are generally considered to have a longer 'touch life' as in number of presses. they go from some few hundred thousand to a million or something. TBH you will never wear out a decent 4 wire panel in your life of your carPC. The benefit is for commercial and public use where panels will get abused and use all day. If you wear out a decent 4 wire you are not spending enough time with your eyes on the road and generally most of us will be a little bit more careful with our screens than joe public on some ticket buying kiosk at the cinema.
    They are however said to be a little be clearer but tbh the glare is more of an issue with resistive than the light transmission.
    Mar 2004
    Bristol
    oh and luckily for you i have a xenarc panel on my desk. it is the old 4 wire but i can confirm the viewable area is just over 90mm high and between 150-155mm wide. so, as I said...get a xenarc one!
    the total panel area is 170x106 but there is obviosuly a border. if you check the specs of the xenarc viewable area then i am pretty sure it is quoted as about 155x90 if i remember rightly.
    Mar 2004
    Bristol
    oh and if it is 16:9 you need then you could for a slightly bigger 4 wire 8" 16:9 touch panel from one of the linitx screens.
    Mar 2004
    Question for you, the old 4 wire, and new 5 wire tsv's the only thing different is the touch controller? if i have a 5 wire tsv, would I be able to swap to a 4 wire controller?
    Mar 2004
    Bristol
    should be the same pinout to the controller yes. so yes you should be able to just put in a 5 wire panel and controller.
    ps did your mother ever teach you to use your P's and Q's?
  1. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 05:20 PM
  2. touchscreen panel controller wire of lilliput
    By ove1kenove in forum LCD/Display
    Last Post: 06-25-2005, 03:43 PM
  3. New Lilliput Touch Panel install have question
    By PHiLiSO in forum LCD/Display
    Last Post: 08-04-2004, 03:18 AM
  4. 3M Touch panel?
    By Sh0cker in forum Input Devices
    Last Post: 11-25-2003, 11:43 PM
