not only a beefy sytem, but you'l have to go outside & run your car for 15 min each hour to not kill the battery... when recording like this, power consumtion will be up there...
I think the best way to REALLY do this is to base it on a camcorder device,
you can also use a microwave sensor set on max, so any movement within a few feet of the vehicle triggers recording...
on a pc while parked for hours & hours will need a whole bank of aux batteries, & even if you went to that extent, chances are your parked to driving ratio isn't high enough to maintain a charge on the aux bank.....
camcorder based...., paired with a 4 ch multiplexer...
LinkBack URL
About LinkBacks
