Results 1 to 10 of 14
Thread: Powermate Interface for Roadrunner
    Nov 2005
    Austria
    Hi everybody.
    I need some beta-tester for a little tool I wrote. The tool only works with Powermate & Roadrunner at the moment. If anybody is intressted, please post. Then I will make a setup.
    regards
    quickmic
    Variable Bitrate redls1bird's Avatar
    Feb 2006
    hey quick, i have a powermate, and i plan on using rr. its definately not in fully operational mode yet, but i could still play around if you wanted some input.
    Car Pc progress meter:
    [-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    Oct 2004
    Toronto
    I've got a powermate and use rr with LSX_Void, happy to test for you...LMK
    Nov 2005
    Austria
    Here is the Link:
    http://www.quickmic.at.tt/Public/Pow...face_Setup.zip
    Primary check out, if the tool detects correctly the Powermate.
    The Powermate-Commandos have to be displayed in the textbox. If this works correct, you can try change the "KeyTBL.ini" and see, how it works with Roadrunner. But there are still some bugs.... beta
    Nov 2005
    Austria
    Here a small manual:
    If you work wirh roadrunner, the tool has 2 modes.
    First mode (Audio-mode):
    Left=Vol-
    Right=Vol+
    Click=Play/Pause
    Down & Left=Prev Song
    Down & Right=Next Song
    Second mode (Menu-mode):
    Left=Curser left
    Right=Curser Right
    Click=Enter
    DBLClick=Select the Element ...... i.e. the Element is a Slider, then the "left/right" is changed to "up/down" (adjust the Slider)... Next DBLClick deselects the Element ("left/right is "left/right")
    To change the Mode, make a long click (600ms)
    Default mode is "Audio mode". If you have changed to "Menu-Mode", a timer is started, which goes back after 10 sec. to "Audio mode", if you do "nothing"
    Dec 2000
    Short results: I tested it out and it works
    Long results: I just got my powermate yesterday and I've been playing around with using the manufacturer's software and with girder + plugin. The girder method requires that you have the Powermate driver installed but not run the powermate application (for obvious reason). So, this is what I had when I downloaded your app (driver installed but not running either of the other applications). I ran runme.bat and it was successful as registering the ocx. Then I ran powermate.exe and I get a dialog box titled HIDInterface with the message "Nothing found" followed by another dialog box titled Powermate interface with the same message. Then the little window with a text box comes up that correctly displays the controller's state. So I replaced my default keytbl.ini with yours and fire up RR (which is using LSX Void). Works great. Only issues I noticed are: 1) that LSX's volume display bar does not reflect the change to the volume but I imagine I just need to edit keytbl for lsx and 2) that the program does not want to close (hit close on the little window, then hit the powermate and it will exit with an error).
    A couple questions:
    I really want to use two powermates and from what I've read this isn't possible (though I think I read that it may be possible with girder and the plugin). Do you plan to support two powermates? That would be great! Also, any plans to open source this?
    Nov 2005
    Austria
    Thx for testing...
    I think, the volume bar doesn't display the master volume, but the tool changes only the master volume. Later this can be adjusted by the Powermate-tool, but for now you can change this by roadrunner.
    Closing the tool is a littlebit buggy for the moment. I try to fix this for the next update.
    2 Powermates should be possible, but I have only one. So I cannot programm this feature, but I upload the code also by the next update. So maybe anyone else can make the support for 2 devices.
    Dec 2000
    Sounds great, I'll test whatever you post.
    As far as two powermates, when I was searching to see if two were possible, I came across a number of threads that said it wasn't but then others where people were saying that they were putting in two (maybe it was a plan that they had not fully researched). If it seems possible, I could pick up another one and possibly contribute some code.
    Dec 2000
    Quote Originally Posted by quickmic View Post
    Thx for testing...
    In between coats on my lcd bezel I checked the keycode thing. I changed one of the commands for an existing keycode (in keytbl.ini) that you've got you're app send to VOL+ and another to VOL- and it works like a charm changing the volume through rr and so the volume bar shows the change.
    BTW, are you using microsoft's DDK for this?
    Nov 2005
    Austria
    Here the new version:
    http://www.quickmic.at.tt/Public/Pow...e_Setup_06.rar
    I've fixed some bugs and make the tool more adjustable. Also click-sound is now supported and closing the tool should work correctly.
  1. Toy For Christmas (PowerMate)
    By chuckster in forum Road Runner
    Last Post: 02-10-2006, 08:24 AM
  2. How About A Powermate Driven Front End?
    By ukchris in forum Software & Software Development
    Last Post: 01-22-2006, 07:58 AM
  3. XMdirect cable + Sony Unilink Interface. help!
    By d2.n in forum General Hardware Discussion
    Last Post: 03-17-2005, 04:36 PM
  4. ultra tiny interface
    By skullman in forum Input Devices
    Last Post: 03-22-2004, 03:53 PM
  5. A few questions about an interface
    By naevity in forum Software & Software Development
    Last Post: 10-03-2002, 10:31 PM
