Results 1 to 7 of 7
Thread: Infared Codes all the same
    Newbie linkyone's Avatar
    Apr 2005
    Italy
    I have girder, a USB UIRT, and an RCA ir keyboard. When trying to capture the ir code from the KB i get the same code for each key. it almost seems as if it spits out 2 codes the first is different and the second the same and girder is missing the first code. is there anyway to fix this issue? i have the same problem with my Pioneer remote. some of the keys all perform the same function.
    Jul 2003
    Northants, Uk
    no there are different codes for IR and you would need different ir recievers for them
    Apr 2005
    Italy
    Well, yea, i know there are different codes per button on a remote but here is the issue. on my Pioneer remote it has about 20 buttons. i can "learn" the directional buttons with no problem but when i try to program the 1-9 buttons at the bottom they all seem to give me the same code in girder. thats why i am confused, some are different and some are the same.
    Mar 2006
    Colorado, but Canadian!
    It could have multiple signals for each press. Like sending a signal notifying the unit of sending a signal, another burst for the info, and another burst for saying done. So if you only get the last, then the code you get is "done" each time.
    I've seen devices with this but usually not remotes.
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2005
    Italy
    that makes sense. is there anyway for me to capture the entire code and be able to use those keys?
    Jul 2003
    Northants, Uk
    what i meant was that some remotes for example the bush remote with the keyboard in the middle people on here where using, needed a 38hz receiver for the standard remote and a second receiver on a different frequency for the keyboard. your receiver may not have a wide enough receiver band for all the remote codes
    Apr 2005
    Italy
    Junior
    would i still need a second reciever if i still recieve a code at all? I do get a code on every button i press but it seems to always be the same code. is there a way to filter out the common parts of the code string and only get the data part of the <Start>-<Data>-<stop> code. <- refering to what 2k1Toaster Said
    2K1Toaster
    i am using a pioneer car stereo remote and an old RCA WebTV keyboard.
  1. Lilliput Programming Guide, More Reset Codes
    By Anointed in forum LCD/Display
    Last Post: 07-15-2011, 09:28 PM
  2. Are there any scanners or readers that can display all codes on the bus?
    By makaveli200369 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-23-2006, 01:03 AM
  3. Pioneer Infared remote to control RR
    By linkyone in forum Road Runner
    Last Post: 03-08-2006, 03:30 AM
  4. Mazda PID codes?
    By coffeejolts in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-16-2006, 12:13 PM
  5. WTB: Lilliput Infared Opening Cover
    By hussein in forum Classified Archive
    Last Post: 10-20-2004, 01:52 AM
