Page 10 of 24 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 234
Thread: Lets see those rearview camera mounts.
  1. #91
    Jun 2007
  2. #92
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    They all look the same to me.
  3. #93
    Jun 2007
    Quote Originally Posted by Curiosity View Post
    one says 1/3" and the other says 1/4" CMOS ? is 1/4 better them 1/3 in this case, thanks
  4. #94
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    The first two look the same the third has a different camera lens (if the photos are accurate)
    1/3" is a bigger sensor the 1/4" and therefore could more sensitive or higher resolution. The extra wire on that camera is to mirror the image (See your second link) Mirroring the image on a Sharp chipset is easy, they have a pin that turns it on and off on the actual chip. The camera I used has a Panasonic chipset, which can mirror...if I wire up a microprocessor and hack the thing apart.
    It is going to rain soon here, otherwise I would do my ghetto mirror modification...that is aim the camera down at a 45-degree mirror in order to reverse the image.
    Also don't forget that FOV is typically measured corner-to-corner, my camera has a 120FOV rating, that is equal to 90degree's left to right on the image.
    Here is an image I took on my way home today:
    The car behind me was much closer looking in my rear view mirror, I couldn't see his plates for example.
    Sorry for no comparison photo though, as the light turned green before I could take one.
  5. #95
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by zapwizard View Post
    How's it deal with headlight glare at night?
  6. #96
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  7. #97
    Aug 2002
    Austin, TX
    I haven't driven at night with it yet, so I can't say.
  8. #98
    Apr 2005
    Boston, MA
    I know with the Nitemax cameras (and even the Savv), lights bloom quite a bit. Not a huge issue in an RV cam though.
  9. #99
    Mar 2005
    Sweden/Vaxjo
    Really nice thread... subscribing to it...
    I have one small question though, since everyone else seems to be asking about their cams I might aswell do the same...
    I got this one from my GF a while back as a birthdaypresent:
    (the text is in swedish but u can atleast see how it looks)
    and some specs:
    Now I'm having problems how to connect it to my carpc... I can run it directly to my screen and just switch to the AV1 to see it but I want to be able to record it... so I was thinking of getting one of these:
    http://www.hauppauge.com/pages/produ...impactvcb.html
    I havn't fiddled much with cams before but that would make it possible to get the cam into any windows software right... if so I might just get 2 more cams, one pointing forward and one inside or something... strange things is happening sometimes in my rear seat...
    (sorry for all the pics btw!)
    Swedish site for CarPC's
    http://www.bilpc.info
  10. #100
    Mar 2006
    Colorado, but Canadian!
    That camera seems as if it would only work in the day time. Its lux ratings are really sucky.
    But when you get those video in cards, there are some things to consider. 1 would be the encoding. Your camera says PAL/NTSC so you should be ok there. The second thing would be where the video processing is done. The cheap ones are just an interface with your CPU. Basically like onboard video. It is a parasite off of the CPU. So if you have a via board, you can kiss that option goodbye. The more expensive ones have onboard video chips so your cpu does less work, and the card does more work.
    So to sum up. If you have a P4 or something, then any card will do. If you have a low-power or old system, then you need an oncard video chip.
    1.9in x 2.9in -- 47mm x 73mm
  1. Can any camera work for rearview camera?
    By polo6979 in forum StreetDeck
    Last Post: 09-27-2006, 09:16 AM
  2. Wiring help for Rearview Camera
    By maxxell in forum Newbie
    Last Post: 08-05-2006, 02:23 AM
  3. rearview camera
    By biomekanik in forum Newbie
    Last Post: 06-09-2005, 12:23 PM
  4. Replies: 0
    Last Post: 03-16-2005, 01:41 AM
  5. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:21 PM
