Page 16 of 24 FirstFirst ... 6789101112131415161718192021222324 LastLast
Results 151 to 160 of 234
Thread: Lets see those rearview camera mounts.
  1. #151
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Quote Originally Posted by bes51659 View Post
    I guess that you do not notice corners as long as it is symetrical...
    DVR seems nice... To expensive for me. I went to eBay and just bought this
    the dvr was a cheaper option for me at the time when i didn't have a carpc. if and when i have a running carpc in the car 24/7, i plan to go that usb route as well. i'm thinking of getting a 4 channel one.
    Quote Originally Posted by jbradshw View Post
    lacning - you have the same Lilliput I do - does yours autoswitch when the cam turns on? I know there's a thread on this new Lilliput and its features - the autoswitch feature is a bit questionable though as it appears only maybe a few people got it working. I want to add a rearcam but I'm not gonna bother if I can't get the autoswitching to work.
    my unlucky Lilliput doesn't seem to have that selection in the secret menu. either way, my back-up cam isn't wired to the back-up light but to a ignition switched fuse so it's always on when i'm driving. that's why i needed the lower control buttons of the screen exposed in my install.
  2. #152
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    (Not knowing what the problem is with the Lilliput)
    Maybe you should have a look at my powercontrol kit. My CID 650 LCD panel has a control signal input for selecting AV2 as input. Problem is to get back to VGA afterwards if it was not active when camera was selected. Major problem when the panel is fitted into the dash without the buttons as I have done.
    I want it to be totaly automatic. I solved this by enabling VGA for a few seconds before activating AV2, and holding on to VGA 2s after deactivating AV2. Things that can be done with CPU only.
  3. #153
    Apr 2008
    i decided to delete my rear wiper and mount my new power acoustik ccd-5xs camera over/through the hole.
  4. #154
    Sep 2005
    Beautiful! It never rains in the apple anyway, does it :-)
    I like the mount, even though the camera was a bit on the pricy side. Do you have any screen shoots? I have got my composite to USB adapter now so there will soon be pictures from my device.
  5. #155
    Apr 2008
    the video is running into video 1 of my touchscreen so i can't save a screenshot. i plan on getting a usb adapter 4 channel dvr to also hook up my dashcam later.
    i have been through 3 "cheaper" back-up cameras. you get what you pay for. as a general rule, ccd chips fare better than cmos. low lux is important. lots of cameras can compensate by using ir leds but quality varies. bascially, get a camera you can afford to replace or at least return it without hassle.
  6. #156
    Jan 2008
    MD, USA
    I've been looking for a OEM Toyota camera to use, no luck yet finding one. I like how it preforms on my Pruis.
    CarPC: Mini-MAC Coming Soon!
  7. #157
    Constant Bitrate scatebase's Avatar
    Oct 2008
    I saw this the other day and thought it might be interesting. A little pricey, but might be worth it if it looks good.
    sanyo cca-bc200
    review
  8. #158
    Apr 2008
    Quote Originally Posted by scatebase View Post
    sanyo cca-bc200
    review
    it looks like a good quality one by a respectable manufacturer. i like the image distortion compensation feature. the lux rating is not that low though. good enough during the day but might be an issue at night even with the reverse lights.
  9. #159
    Oct 2008
    Quote Originally Posted by lacning74 View Post
    That's the only thing keeping me from picking one up. I might do it anyways.
  10. #160
    Jan 2008
    MD, USA
    I was going to pick one up also, but decided i'll just try to find a OEM Toyota unit. They actually work great.
  1. Can any camera work for rearview camera?
    By polo6979 in forum StreetDeck
    Last Post: 09-27-2006, 09:16 AM
  2. Wiring help for Rearview Camera
    By maxxell in forum Newbie
    Last Post: 08-05-2006, 02:23 AM
  3. rearview camera
    By biomekanik in forum Newbie
    Last Post: 06-09-2005, 12:23 PM
  4. Replies: 0
    Last Post: 03-16-2005, 01:41 AM
  5. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:21 PM
