Page 5 of 24 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 234
Thread: Lets see those rearview camera mounts.
  1. #41
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    Quote Originally Posted by pRoFiT View Post
    Okay i found it today. Saw this at costco. Cant find on there site but found it here. It screws to your license plate.
    http://www.roadmasterusa.com/backupcamera_vr3.php
    Hope this helps.
    Can't tell you how many times i see this ^^ in my rear view...
    I guess the milfs just love my suby...
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
  2. #42
    Mar 2005
    Pomona, CA
    I find I don't really need the IR emitters. The trick I use, is to press on the brakes lightly when I am reversing. The red light works just as good as the white light when it is dark out. There is no way I would have installed a reverse cam if it had to be the huge ones with the lights around them.
  3. #43
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    That looks like an excellent install.
    Was it tricky drilling the cover and housing to fit the camera? Also does your brake light look much different (have a big black spot in the middle of it)?
    I installed my carpc into my pet Kangaroo, mate.
  4. #44
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by sivart321 View Post
    Nice stealthy install
  5. #45
    Mar 2005
    Pomona, CA
    Not much difference, the 3rd brake light had 3 bulbs in it originally... the way it is now, it's only slightly dimmer than before. Hardly noticeable.
    I bought an extra third brake light from a the classifieds section of another forum in case I screwed mine up. I ended up using a step drill and got it to work the first time without problems. I used black silicone to seal the outside, and epoxy to secure the rear of the camera in the housing. The reflector is still in tact, so the other 2 bulbs still reflect some in the center outputting a little light.
  6. #46
    Mar 2006
    Colorado, but Canadian!
    It looks really good just to let you know!
    1.9in x 2.9in -- 47mm x 73mm
  7. #47
    FLAC sama's Avatar
    Feb 2006
    London, UK
    top marks for originality dude, and the screen looks great too
  8. #48
    Nov 2006
    On a side note, I contacted Ford spare parts here in Australia as the Ford Territory (4x4) comes standard with a reversing camera, mounted in a nice little housing under the trim on the rear hatch. I thought perhaps it might be something that I could use in my reversing camera setup. The conversation went as follows:
    Me - Hi I've damaged my reversing camera on my Territory and am wanting a replacement
    Ford Parts Guy - I've never had to sell a replacement before. Let me find the part number and price
    Me - Ok, now worries
    *A couple of minutes pass by*
    For Parts Guy - So you've damaged the camera?
    Me - Yes
    Ford Parts Guy - A replacement is going to cost you Aud$1057.43
    Me - *silence*
    Ford Parts Guy - That's for the camera itself
    Me - Oh ok, I might learn to live with it broken then. Thanks
    Moral of the story. Stick with ebay or jaycar
  9. #49
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    good story. I'm looking around... ebay looks good...
  10. #50
    Oct 2004
    NY
    I wanted a really good camera since I don't have a rearview mirror, & my camera is my only view... all of the rear view cameras out there are just not real high end at all, I went with a sony superHAD 1/3" chip camera, 520 lines resolution, .02 lux native without infrared assist... it came in a large outdoor security camera case that I took apart & chopped down, then built my own bracket to mount it, isolated on rubber vibration dampeners & added an adjustment for finetuning the angle
    this camera see's through the wiper hole in my tailgate... since I don't actually have to look through the window, there was no need for a wiper anyway... from outside you don't even see the camera, theres a tinted glass inside the hole, the camera is inside...
  1. Can any camera work for rearview camera?
    By polo6979 in forum StreetDeck
    Last Post: 09-27-2006, 09:16 AM
  2. Wiring help for Rearview Camera
    By maxxell in forum Newbie
    Last Post: 08-05-2006, 02:23 AM
  3. rearview camera
    By biomekanik in forum Newbie
    Last Post: 06-09-2005, 12:23 PM
  4. Replies: 0
    Last Post: 03-16-2005, 01:41 AM
  5. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:21 PM
