Results 1 to 6 of 6
Thread: car2pc driver
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    car2pc driver
    I plug in the unit into the usb port on the car pc and I run through the installation. A little while after following through the steps I get asked to insert the "FTDI USB Drivers Disk" and if I click ok it asks me to locate the file "ftdiun2k.ini". I am running Windows XP SP2. I've tried pointing it to the car2pc cd which came with it but it cant find it there. I searched on google and downloaded a ftdiun2k.ini it installed the car2pc adaptor but then it created a new device called FTDI Serial USB and it wasn't able to find any drivers for that device. And in all cases I wasn't able to get the car2pc adaptor to work with RR or Winamp.
    Any ideas?
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    FLAC jbors's Avatar
    Nov 2003
    Please uninstall that driver and use this one instead:
    http://car2pc.com/downloads/ftdi_win32_car2pc.zip
    Sorry for that.
    Car pc integration with ease
    Car mediacenter
    Tried using that driver but now it asks for ftdibus.sys. So I pointed it to the ftdibus.sys in the old driver files, it then asked for ftdiun2k.ini, so I downloaded a copy of the net and used that but then a new device called "Usb serial adaptor" is then created and it can't find any drivers for it.
    Fox Mulder
    2004 Toyota MR2
    Managed to get it to work, I got it to the point where it asked me to find drivers for the USB to serial Adaptor but I juct clicked cancel and it worked.
    Fox Mulder
    2004 Toyota MR2
    FLAC jbors's Avatar
    Nov 2003
    Just wanted to say that you can use Serial drivers and it will work, however I founfd out that it is not very stable. So I would suggest uninstall that and use D2XX drivers instead:
    Just make sure you delete inf file from \windows\inf folder. It is usually named oem*.inf.
    Car mediacenter
    Mar 2010
    Istanbul,Turkey
    I need Windows7 64bit driver. Where can i find it? Anyone help please.
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 10:32 AM
  2. Replies: 33
    Last Post: 05-07-2008, 10:24 PM
  3. RR 7-8-06.. Pic Viewer & more
    By guino in forum Road Runner
    Last Post: 09-11-2006, 01:35 PM
  4. Driver Issues (PL-2303 Driver)
    By PharmD Heel in forum GPS
    Last Post: 08-29-2006, 05:31 PM
  5. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 06:18 PM
