Results 1 to 3 of 3
Thread: USB TOuch Screen not working after install?
    Registered User belezeebub's Avatar
    Dec 2003
    OKay I tested my carpc for a week before I hit the stero shop to have it installed it worked fine before but its not even detected after being installled, I am thinking the 10-foot USB extension cable is the issue anyone had this problem before? or know of a fix? I suppose if I have to IU can go get a USB hub / repeter run a power supply and try that.
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    you should stick always w/ USB 1.1 for TS, 10ft. should not have any problems to get you TS through it, maybe the cable got chewed in the installation, did you check it with something else?
    You can always purchase a USB to Ethernet plug and that way make your own lenght with no worries over latency.
    08 Lincoln Navigator www.mobiteklink.com
    Dec 2003
    I have two USB cabled one for the GPS one for the TS I switched them TS still doesn't work but its a Mute point now the Brand New Screen I purchased from Digitalww died waiting for a responce back from him to see where I go next.
  1. Replies: 4
    Last Post: 07-28-2006, 11:12 AM
  2. Dynamix touch screen not working after standby (S3)
    By mrloofer in forum LCD/Display
    Last Post: 05-10-2006, 03:04 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  5. Xenarc Touch Not Working
    By MSUC5Vette in forum LCD/Display
    Last Post: 08-18-2004, 12:42 PM
