Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: External Slimline DVD enclosure
    Apr 2005
    Queens, New York
    Well as I have and I have found that plenty of people are having the same problem as I am having. My toshiba DVD drive does not work correctly. When the drive is connected (via USB) directly ot the PC with a 10ft USB cable the drive just blinks and XP doesnt read it. IT does the same exact thing when it is connected to my USB HUB. As you can see in my picture my drive is fabricated into my dash bezel and it would be a realy pain in the *** to remove the drive:
    What I have done to try and correct the problem:
    • Next I tapped off of my OPUS' 5V line and ran it to the drive. That KIND OF worked but it would read it then it would stop responding.
    • The last thing i have done was to connect a 5v to an Opus POL and it did the same thing as the last.
    So What should I do next? Can it be the drive? Or should i try a different enclosure?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    That looks like a slot-load in your bezel rather then the "tray-load" in the link.
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    try a active usb extension cable.
    Apr 2005
    Queens, New York
    Quote Originally Posted by legacy05gt View Post
    Well that is just the enclosure...
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2005
    Queens, New York
    Quote Originally Posted by pate60 View Post
    You think it is just too long of a distance and it cant power it?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by Cheekz185 View Post
    Check to make sure there is no power connection or line next to the usb wire that is giving it interference. That would do it alot of time too
    Dec 2005
    try shorter cable. (3-6 feet).
    my external drive was hanging a lot in my htpc until I changed the shorter cable.
    Apr 2005
    Queens, New York
    Quote Originally Posted by 0-0-7 View Post
    Well i cant go any shorter cuz then it wont reach....
    Quote Originally Posted by tn6478 View Post
    I have the cable wrapped around my VGA extension cable wrapped with some TechFlex. I dont think it is the power wires causing it cuz i put a brand new direct USB 10ft cable it still didnt work....BUT when i was test benching everything in my house i used like a 3ft cable and it worked perfectly....
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    i think you just answered your own question
    3ft works 10ft doesnt work.
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
    Apr 2005
    Queens, New York
    IM going to try a active USB cable...
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. External DVD stops the PC booting
    By Tim Lake in forum Power Supplies
    Last Post: 11-14-2006, 01:56 AM
  2. 1394b external enclosure for slim optical drive
    By ross0015 in forum General Hardware Discussion
    Last Post: 06-14-2005, 03:43 PM
  3. Replies: 18
    Last Post: 05-07-2005, 02:02 PM
  4. Slimline DVD adapter
    By mdray00 in forum Newbie
    Last Post: 02-22-2005, 06:41 AM
  5. FS: External Slim Line DVD burner for sale!
    By EsKALad in forum Classified Archive
    Last Post: 02-06-2005, 08:48 PM
