Results 1 to 9 of 9
Thread: Help with a Slot load panasonic
    Oct 2006
    Hi all,
    i have just recieved a Panasonic UJ-815-B off ebay *clicky*. However when i have it in my car pc its not detected on the boot up, then i get an error a minute or so later saying theres no bootable device :/ if i remove it it boots from the HD fine.
    i then tried it in two other machines, one laptop and my desktop pc. It was fine in both of these machines!
    The main problem is that i can see the drive on the LT and DT but i cant insert any media into it. it goes in until there is about 2cm of the cd out, a few lights flash and it spits it back out!
    is this a dud as the guy clearly states it was working? i have contacted him but i have not heard anything back yet.
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by buzza View Post
    Hi all,
    Broken unit
    Oct 2006
    i dont have a manual
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    im not too familiar with laptop drives but i think those use jumpers to set slave/master like the 3.5s. check that the jumpers on the drive arent set to master.
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
    Oct 2006
    there isnt any jumpers on it :/. im sending it back to the guy tomorrow so hopefully he has the same problem!
    Sep 2005
    The no bootable device error sounds like you have the DVD drive set as the primary boot device. You can change that in your BIOS, but it doesn't sound like it will solve any problems except that bootup error.
    _
    Mar 2004
    Little Elm, Texas
    I've been running into all kinds of computability problems with the Panasonic drives.
    I'm using a MA external enclosure. It seems that the board inside the enclosure doesn't like the Panasonics for some reason. A cheapo TEAC works fine on it. I've tried 3 different Panasonics, all brand new. Take it directly from not working in the car and slide it into my laptop and it works fine.
    I would try another drive if I were you. I know it sucks because you've already bought it and paid for it.
    Perhaps you can try it in a laptop or the like?
    This makes me wonder how many others have run into compatibility issues with the Panasonic drives.
    Jan Bennett
    Oct 2006
    thanks for the replies!
    i have tried it in a laptop and it booted fine, i still have the issue of not being able to insert a disc into it. i then tried it in my desktop pc and i had the same problems.
    i have tried two other laptop dvd drives init, one sony and the other i dont know the make and they worked fine. ive sent it back today so i just hope the guy has the same problem!
    _
    Mar 2004
    Little Elm, Texas
    I've started a post over here as I'm seeing more and more problems with these drives....:Panasonic CW-8123B, CW-8124B, UJ-825, and UJ-845
    Jan Bennett
  1. Hacking Head Unit CD with CD/DVD-ROM slot load drive?
    By pktloss in forum Hardware Development
    Last Post: 03-25-2006, 10:42 PM
  2. Panasonic Slot Load DVD-ROM/CD-RW BRAND NEW
    By arawas in forum Classified Archive
    Last Post: 03-10-2006, 01:22 PM
  3. FS: Panasonic UJ-815B DVDRW/CDRW
    By A-Z in forum Classified Archive
    Last Post: 10-03-2005, 03:16 PM
  4. slot load dvd rom????
    By xtreamvette in forum General Hardware Discussion
    Last Post: 09-30-2004, 07:02 PM
  5. Can a slot load DVD/CD-ROM be operated upside down?
    By archimense in forum General Hardware Discussion
    Last Post: 06-25-2004, 04:01 PM
