Results 1 to 6 of 6
Thread: Straight from mobo component to LCD component?
    Nov 2006
    Can I go straight from a component off the back of a pc motherboard into an lcd screen that has a/v component inputs? Im in the process of building a carputer setup but I dont want to have to go through the process of trying to find a vga lcd if I can do with a/v components. I found a nice motorized screen on ebay but its component only.
    I was thinking I could build the pc then display video from it with the yellow video component on the back of the motherboard. Is this possible?
    Thanks everyone
    MantisX
    Elsewhere
    I don't know of a motherboard on the market that has component video (the red, green blue RCA hookups).
    I'm thinking you mean composite video.
    And yes, that will work if you have a motherboard that has a TV-out capability.
    Understand that you will likely not be happy with the quality of the video using a composite signal.
    And there are plenty of VGA screens to be had. Have you looked in the store here? DigitalWW? LogicSupply?
    How about the Wiki?
    Nov 2006
    Hi. Yes you are right, it was composite. I got a little mixed up there. Basically its the same connector that would be on the back of a tv. How bad is the quality of a composite as opposed to the vga? I noticed so far that the price nearly doubled just for a vga connection and most of them arent motorized as well.
    MantisX
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by MantisX View Post
    MantisX
    I use a composite cable form my tv out to my tele to watch my episodes of Top Gear and Mythbusters etc. The video itself is perfect, however the text of the folder and window names and menu's etc is almost unreadable. This is on a 68cm tv btw
    I installed my carpc into my pet Kangaroo, mate.
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    Good enough for TV but not PC. I've got a few pics at http://members.chello.se/bengt-olof....gn_history.htm
    Use VGA or Component.
    Composite is a tv signal without sound and not modulated on carrier. It is also interlaced, and frames are updated with 25Hz(PAL) or 30Hz(NTSC). Colour is still modulated on its subcarrier. NTSC on 3.58MHz and PAL on 4.43MHz.
    Resolution is restricted to avoid flickering due to interlacing. You get about 300 lines in NTSC (400 in PAL) and 350 pixels horizontally (PAL & NTSC) independent on 4:3 or 16:9.
    I think that colour resolution might be even worse.
    Have a lock at http://en.wikipedia.org/wiki/Composite_video
    Best of luck!
    Nov 2006
    Thanks everyone. After viewing those pictures, I think im pretty much decided on VGA. My whole reason for the carputer was GPS and music. Id like to be able to read my windows desktop clearly so it seems vga is the only real option.
    Thanks again
    MantisX
  1. 8.4" LCD in WRX dash.
    By Giuliano in forum LCD/Display
    Last Post: 08-07-2010, 03:27 AM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
