Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 60
Thread: Pioneer Wired remote control
  1. #31
    Mar 2009
    No, I did not connect 5V! With my radio (Pioneer DEH P7900UB) I only connect te tip and sleev via a resistor (5 different ones) and I got the 5 functions.
    Success!
  2. #32
    Feb 2009
    I still can not get this to work. All I need to be able to do is control the Source function of the stereo so I can swap between AUX IN and Radio from the drivers seat when the stereo is in the boot.
    Any ideas???
  3. #33
    Mar 2009
    I now have installed my radio with a new facial adapter. So I finally can enjoy CD and USB music input.
    I only need to connect the remote factory control to the radio.
    I have measured the resistors in the remote control and they seem to be quit different.
    Now I have to find a way to open the remote control and change the resistors.
    First I have to see how I can get the remote control out of the steering wheel.
    I will keep you informed.
  4. #34
    Feb 2009
    Thank you
  5. #35
    Feb 2009
    Does anyone kow if the SONY RM-X2S stick remote is compatible with a Pioneer HU? I'm clutching at straws here, but all I need is to be able to select between Radio and AUX IN remotely.
    I don't even mind if I need to buy a new HU that has both wired remote and aux input if anyone could suggest one or two. I can't seem to find any.
  6. #36
    Mar 2009
    I finally got it working on my Mazda Premacy!
    I had to modify my remote steering wheel controller: other resistors and some rewiring.
    Before I started building the whole thing in my car, I had made a print with resistors for 5 funtcions. I tried it on my car radio on my desk (still not in my car at that time). It worked.
    Than I modified the remote controller and build the whole thing, including my radio in the car and......nothing happened....the controller didn't work! pffff :-(
    I measured the different resistances when pushing the controller buttons and they all seem to be okay. I checked the jack....also okay....I really didn't know, where possibly could be the problem.
    Than after half an hour searching, I tried a last thing: I swapped two wires , so the resistors came on another position in the wiring (with still the same resistance numbers between tip and sleeve of the jack).
    Amd now, it worked!
  7. #37
    Feb 2009
    Glad you managed to get it to work mate. I'm still really struggling to get any response out of my HU. Maybe I am connecting it wrong. Probably doing something really stupid.
    This is basically how I have it connected. I am just basically shorting out a 2.2kohm resistor between the tip and sleeve, but nothing seems to be happening.
  8. #38
    Mar 2009
    Hey Ray,
    That's exactly how I connected in the test environment and with my radio it worked great.
    Did you connect all the wires of the radio (and I specially mean the several + wires (red and yellow, normally))?
  9. #39
    Feb 2009
    Yes mate. The stereo is in my boot working fine. I just plugged the ISO coonector straight into my ISO to BMW adaptor. The HU works perfectly, I just cant get the jack plug to work.
    I thought maybe the resistor was duff, but it measured out at exactly 2.2kohm. Might try another value tonight. Maybe 4.4 or 6.6k.
  10. #40
    Mar 2009
    Hey Ray,
    Perhaps a silly question, but I am thinking of how to solve this; it is a challenge for me too :-)
    Does the source switching work on your head unit?
    I know, on my Pioneer, I have to turn on the AUX1 in the options, otherwise, the source function skips the AUX1.
    But now I am thinking of it, with your radio and controller, it also does not change to the different radio wavelengths, does it (FM, AM...)?
    Have you already tried other functions with other resistors?
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 10:56 AM
  2. PC Remote Control 4
    By Gene in forum Software & Software Development
    Last Post: 07-03-2005, 10:35 PM
  3. Linitx screen - Remote control
    By Gobby in forum LCD/Display
    Last Post: 01-31-2005, 07:08 PM
  4. WOL and Remote Control by PDA
    By NOS TANG in forum Wireless Communications
    Last Post: 01-08-2005, 04:44 PM
  5. Replies: 3
    Last Post: 05-26-2004, 05:08 AM
