Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: Pioneer Wired remote control
  1. #51
    Sep 2008
    Quote Originally Posted by Tyrekicker View Post
    Hi JVDE,
    You are the indicated person, I thought Ive solved the issue by myself, but now, Iīm īhaving some malfunction, please coul you help me with a diagram of how youīre connecting this three wires, and how resistors and switches are dispossed on you project board? Please let me how the resistor values whic youīre using.
    Thanks in advance by your kind help,
    Tyrekicker
    Radical Tuning Car Quito
    sure! I'm drawing the scematic right now! will post it here and on my homepage.
  2. #52
    Sep 2008
  3. #53
    Jan 2009
    Thanks JVDE,
    I have a Question, I want to connect my Corsa VXR steering wheel remote control, but I have three wires, one for the ground which are connected to car ground, one for the electric antena wire which turn on buttons lightning when stereo turns on, and one wire to the stereo for remote control signal, I donīt have the folder buttons, just havve this buttons:
    -Source/off
    -tune up/next track
    -tune down/previous track
    -volume up
    -volume down
    -ATT
    I think itīs possible, because I donīt need to connect anything to the ring, but when Iīve connected, just works the source button, and the other buttons works like ATT, all buttons turn on its lightning when stereo turns on, do you think I have to replace the genuine resistors with this values and all works well? Are you sure itīs +5V DC, or ground power?
    Sorry for a lot of questions,
    Iīm using a Pioneer AVH-P4000DVD unit.
    Nice civic! I love that silver shift knob and its black boot with red threads, I[m planning to do something like that, steering, boots, doors and seats.
  4. #54
    Sep 2008
    Thanks JVDE,
    -Source/off
    -tune up/next track
    -volume up
    -volume down
    -ATT
    Nice civic!
    Hey! tahnk you
    I really think you need all 3 wires. It's a bit strange pioneer build it this way. But that's probably to make it a bit harder for us.
    Can't you use the antenna/light wire as 3th wire? and try to connect your button lights to one of the 5V DC wires? I don't know if that will work but it's worth the try!
    Grtz
  5. #55
    Nov 2009
    pioneer head unit control
    Hi there!!!
    I have found this thread searching in Google information about the wiring of pioneer car audio units. I know it is a bit old this post, but I think it is worth the try to post here my question as I see you all know what you are talking about!!
    I have a pioneer unit, deh3600mp, with a jack for the wired remote in the back. My car has a stalk adaptor, so the controls are not on the steering wheel. The connector of this stalk is square, green or yellow (I am not sure), and I have an original interface from Pioneer, CARPI 034, bought specifically for my car. But it is not right!!!!! Now I would like to check the signals of the interface and those of the connector of the car, so that I can pair signals as I think it is only a problem of different design of the connector, nothing more. But I dont know how to do it.
    Do any of you have any idea about this? I very much appreciate any help on this.
    Regards!!
    masta
  6. #56
    Oct 2005
    Where can i find similar info for Kenwood wired remote?
  7. #57
    Mar 2010
    Miami
    just wondering, im about to order all the stuff to build my own remote on a project board, but you dont need the IPbus and power connectors like you do in the original remote kits?
    Or will it work just by plugging it into the 3.5 connector on the back?
  8. #58
    Jul 2010
    Look at this wheel remote controll adapter Cir-310U
    http://www.hvi.od.ua/index.php?optio...emid=7&lang=en
    It's can use with Pioneer and any one auto.
    What you say about it ?
  9. #59
    Oct 2006
    Connect to microprocessor
    Has anyone connected a microprocessor to the Pioneer remote input?
    It could of course be done using a set of relays, switching in the appropriate resistor, but perhaps it could be done in a neater way...
    A digital potentiometer was what first came to my mind, but then I thought:
    If the resistor becomes part of a voltage divider inside the unit, maybe the unit is actually looking for a specific voltage, rather than a resistance. In that case, I could simply attach a D/A output from the microprocessor to the input of the Pioneer and set it to generate series of output voltages...
    What do you think?
  10. #60
    Nov 2011
    Quote Originally Posted by roseen View Post
    A digital was what first came to my mind, but then I thought:
    What do you think?
    Hi roseen,
    You don't need either relays or digital potentiometer.
    For this purpose, you can simply use a multiplexer, such as CD4051.
    By the way, because of the voltage drop on diodes(Both Tip and Ring was 3.3v and not 5v), I used ~9.5K ohm instead of 11.25K for "Folder Up/Down".
    And thank you JVDE for the scheme!
    Good luck,
    Albert
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 09:56 AM
  2. PC Remote Control 4
    By Gene in forum Software & Software Development
    Last Post: 07-03-2005, 09:35 PM
  3. Linitx screen - Remote control
    By Gobby in forum LCD/Display
    Last Post: 01-31-2005, 06:08 PM
  4. WOL and Remote Control by PDA
    By NOS TANG in forum Wireless Communications
    Last Post: 01-08-2005, 03:44 PM
  5. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
