+ Reply to Thread
Page 1 of 6 123456 LastLast
Results 1 to 10 of 60
Thread: Pioneer Wired remote control
    Dec 2006
    Italy
    Hi to all,
    I've searched to all forums information on how works "Wired Remote" input of pioneer Car audio (seems that Sony use a similar protocol).
    I know that the connection use a 3,5 mm jack stereo connected to KEYD, KEYAD and GND, inside the car audio unit.
    The wired remote control recognize resistors, It's a serial protocol or use other kind of code ?
    I would want to control the Unit using a PC so I need to know this infomration to make the right interface.
    Thanks in advance
    Mar 2006
    Colorado, but Canadian!
    Usually when you press buttons, a unique resistance is applied to the input voltage of the controller. What gets sent out is the "data" so to say.
    No two buttons produce the same resistance when pressed. So your device must simply change the resistance.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2006
    Italy
    So pioneer Wired Remote Input use a resistors code to control Volume, Scan, etc... ?
    Do you know right values for every command ?
    How this resistors must be connected ?
    GND + KEYD (for some controls like volume, mute...)
    GND + KEYAD (for other controls scan, band...)
    Thanks for your fast response!!!
    Dec 2006
    Hi, tea4two - did you get this working, or find out any more - I am looking for the same information. I believe the wired remote device CD-MR70 is compatible but I am not convinced that only simple resistance values are needed to drive these inputs. There is a pioneer adaptor CA-R-PI.181 that accepts various switch inputs and procides a control signal onto the 3.5mm jack but I have so far been unable to discover what form that control signal takes.
    Dec 2006
    Italy
    I don't know how works pioneer remote control.
    I need this information too.
    I've created this thread to obtain this informations.
    2k1toaster tell us that pioneer uses resistors switch, this information seems right,in fact i've found third part commercial adapters(interfaces) that share sony/pioneer car audio.
    And i've found too that sony use resistors switch at least in old car audio.
    I haven't other informations....
    Please who know more info reply to this post
    Regards.
    Dec 2006
    OK, I've now had some time to play with a Pioneer DEH-2800MP. I found a reference elsewhere that suggested that the Sony hard-wired remote uses the following resistance values:
    0 Ω Off
    2.2k Ω Source
    4.4k Ω Mute
    6.6k Ω List(Disp)
    8.8k Ω Seek up
    12.1k Ω Seek down
    16.8k Ω Volume up
    23.6k Ω Volume down
    33.6k Ω Select
    48.6k Ω Mode
    This works out nicely as a series resistor chain as follows:
    2.2K + 2.2K + 2.2K +2.2K + 3.3K + 4.7K + 6.8K + 10K + 15K
    all nice E12 range values. These are the exact values I have found
    reported elsewhere in a Sony RM-X2S wired remote device.
    When I hooked this up to the tip of the remote conector jack on the Pioneer
    I found the following functions seemed to work:
    0 Ω Off (No apparent effect)
    2.2k Ω Source (switch between CD and radio or OFF if > 2 seconds)
    4.4k Ω Mute (toggles "ATT" on display with muted audio)
    6.6k Ω List(Disp) (No apparent effect)
    8.8k Ω Seek up (Search up-radio or next CD track - hold down to fast forward.)
    12.1k Ω Seek down (Search down-radio or previous CD track)
    16.8k Ω Volume up (Volume up)
    23.6k Ω Volume down (Volume down)
    33.6k Ω Select (No apparent effect)
    48.6k Ω Mode (In radio mode switch between FM1,FM2 and MW.)
    Haven't managed to get any effect on the ring connection of the remote jack
    both tip and ring appear to be tied up to 5v tip (STRKEY1, pin 80 on PE5518A)
    ring (STRKEY2, pin 47 on PE5518A).
    Connecting various resistances between tip and ground of remote jack effectively pull STRKEY1 down to different voltages to trigger the remote control.
    Anyone know what STRKEY2 is supposed to do?
    Dec 2006
    Quote Originally Posted by vic_c View Post
    0 Ω Off
    2.2k Ω Source
    4.4k Ω Mute
    6.6k Ω List(Disp)
    8.8k Ω Seek up
    12.1k Ω Seek down
    16.8k Ω Volume up
    23.6k Ω Volume down
    33.6k Ω Select
    48.6k Ω Mode
    I think I have figured out the function of STRKEY2, pin 47 (KEYAD):
    When kept at 5v all the functions for KEYD are as mentioned above but if KEYAD is pulled down (below about 2.4v) the the function of the seek up and seek down are changed to select the next/previous pre-programmed tuning stored for the current selected radio band.
    All I have to do now is build the cct to interface with the steering stalk switches.
    Jan 2007
    Hi, i have a DEH-2800MP and a control stick with 4 switches which i would like to map as follows:
    switch, function
    1, volume up
    2, seek foward
    3, volume down
    4, seek backward
    How could i do this?
    Jan 2007
    I just went and tested the steering stalk with a mulit-meter and it is simply a 4 way switch with an input.
    So do i simply supply the switch with the 12v accessory supply (blue wire supplying 300mA 12v DC) and put a resistor in series of the value you so kindly worked out for the function desired ?
    Is this signal then applied directly to the unit? which pins do i use on the 3.5mm jack?
    Jan 2007
    Brisbane
    Are there any programs that can read these resistance values through a com port (or any other port) to control functions on a pc? Such as winamp functions or keyboard strokes?
+ Reply to Thread
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 10:56 AM
  2. PC Remote Control 4
    By Gene in forum Software & Software Development
    Last Post: 07-03-2005, 10:35 PM
  3. Linitx screen - Remote control
    By Gobby in forum LCD/Display
    Last Post: 01-31-2005, 07:08 PM
  4. WOL and Remote Control by PDA
    By NOS TANG in forum Wireless Communications
    Last Post: 01-08-2005, 04:44 PM
  5. Replies: 3
    Last Post: 05-26-2004, 05:08 AM
