Results 1 to 10 of 15
Thread: Wiring A Inverter
    Dec 2006
    Wiring A Inverter
    Has anyone wired a inverter to there vehicle for the car pc yet and if so how did you do it.
    Elsewhere
    Many people have wired an inverter to their car.
    And how you wire it really depends on what you want. The one that's currently in my car is wired directly to the battery.
    How about the Wiki?
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Just cut off the cigarrette lighter plug (noting the polarity) and hook up the positive to a 12v source and the negative to ground. I have a relay (fed by an ignition lead) in between the 12v source and the inverter 'cause i can't easily reach the switch on the inverter.
    Nov 2006
    i have 8 gauge wire running directly from the battery
    PC
    AMD 3500+ 2.2Ghz, MSI K9VGM-V Motherboard,
    Geil 512MB PC4200 DDR2-RAM, 7" Lilliput Touchscreen, 30GB HD
    Audio
    300 watt RMS 2 Channel MTX AMP, 500 watt RMS D-Class MTX AMP, 2 Front - 5 1/4" Sony Xplods,
    2 Back - 6 1/2" Sony Xplods, 12" MTX Sub
    Nov 2006
    i Have a 1400 watt inverter. It will run just about anything. I have carpc setup. Tied in to the switch on inverter and ran that to ashtray. Installed hidden switch there. Did same thing with computer switch. I like manual control. Sometimes I want car off but still want my computer running. Inverter powered straight to battery. Can run negative to frame of car anywhere. I was getting feedback through sound from computer. Grounded negative side of sound out on computer. Helped alot.
    Mar 2006
    When i have my inverter on, I can't listen to the radio cause of static. goes for the stock radio hooked up to the antenna or my usb tuner hooked up to the antenna. So according to iceking, I should ground the inverter to the car body? Static
    Cars:
    2001 Lexus es300 carpc Complete!Lexus es300 thread
    CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
    2006 Lexus es330 next project.
    Nov 2006
    Can you take pics of install and show us. Sounds like you need a better ground to start with though. You shouldnt be getting that much static.
    Mar 2006
    pics are in my sig for the most part.
    basically the stock antenna which runs from the rear windshield (wierd lexus defroster doubles as an antenna) goes along the floor on the driver side to the head unit. I spliced the wire with coaxle cable to extend the antenna wire which sounds wonderful. That's all by the glovebox.
    Inverter is in the arm rest plugged into the 2nd cig lighter. There is an extension cord I fished under the carpet and under the seats to the trunk. I connect my laptop from that extension and lilliput to the inverter directly. everything sounds fine with the headunit until I switch on the inverter. Then static overwhelms the sound.
    Quite freaking frustrating.
    Cars:
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by spiike View Post
    Well, I discovered that my inverter (Jensen 300 watt...not the best) sends a 20V AC current down into the car's and computer's ground when switched on, preventing me from connecting the computer to my stock headunit's Aux inputs.
    After some research on this forum, I found that some inverters are apparently more electrically isolated than others. I would guess that your inverter is not as electrically isolated as it should be, and is introducing radio/electrical interference into the antenna system.
    You could buy a different inverter (different brand) from Walmart to see if another inverter reduces the noise...if not, just research and buy a proper 12V power supply (like the Opus, M1 or M2) available here or elsewhere on the web.
    @Darque: Shouldn't this question be moved from the "input devices" thread to "power supplies"?
    Mar 2006
    oh man, that would explain it and also the difference with a 30 dollar inverter from target (like mine) vs the 150 dollar one from bestbuy. btw, I think this should be moved to the proper section as well.
    This is a nubular question, but can you connect a laptop to an opus? I thought those were only for desktops.. Also the lilliput, dvd player, and phone charger go through the inverter.
    Cars:
  1. Wiring an Inverter
    By Swifty in forum Car Audio
    Last Post: 07-04-2006, 05:01 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  3. Wiring Coleman Inverter
    By dsbenjamin in forum Power Supplies
    Last Post: 06-27-2004, 05:08 PM
  4. Inverter Wiring
    By MoniraInc in forum Power Supplies
    Last Post: 06-25-2004, 09:23 PM
  5. Newbie....help regarding inverter and wiring..
    By SlimJimmy in forum Power Supplies
    Last Post: 07-30-2003, 10:55 AM
