Results 1 to 6 of 6
Thread: VERY old pda as touchscreen/remote
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    I've been planning my CarPC lately.. so I got this idea. Instead of buying a lilliput 7" LCD which I can't really afford right now, why not use my very old Palm Vx to control Winamp? So I did. I hooked it up and downloaded the Palm Desktop software off of www.palm.com. I then went to www.winamp.com to search for a plugin for my Palm. I clicked plug-ins then portable devices. I found this great app.. it's called touchamp:
    http://www.winamp.com/plugins/details.php?id=146768
    It works great. After installing it with Palm Desktop, I had to shut down the syncronizer to free up COM PORT 1. I then ran Winamp and opened the app on my Palm. The app works great. The hard buttons are great for easy navigation. no stylus needed. i just use my fingernails if im touching the screen and fingers on the hard buttons.
    I'm going to set this up on a CarPC with the following for a budget system in a 2003 Nissan Xterra 2WD:
    mp3car rca cables - $8
    opus 150w psu - $140
    alpine amp - free
    palm vx - free
    400mhz, 96mb, 250gb computer - free
    total - $148
    i was going to use an inverter, but would rather not have all the crap that comes along in installing that.
    Nov 2006
    Snellville, GA
    Here's the picture of it running on my desk:
    Jul 2006
    McKinney, TX
    hmm... creative...
    the main problems i see would be related to getting the palm to start up with the computer and keeping it charged... have you thought of solutions for these yet?
    '94 Honda Accord EX Sedan
    .2 Kicker L7 12's
    [4 cubes NET @ 35hz w/56^2 port]
    .RF 225.2
    Nov 2006
    Snellville, GA
    i have an area under the stock radio where i can sit the cradle. i was goingt o make a new faceplate for it to fill in the empty space. i haven't gone so far for charging.. maybe i'll have to run an inverter. if i run an inverter just for the pda will it induce any noise into the sound system?
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Good post, I heard about people using old palms and really long serial cables to control there music library from other rooms.
    Check out palm VNC.
    http://palmvnc2.free.fr/
    I used palm vnc until I had the cash for a lili. It allows you to see the pc screen and use the touch as a mouse. If you upgrade to a PDA with a thumbboard it will work too.
    As for the cradle, I mount mine right to the dashboard.
    I've used an inverter for 2 years no noise.
    good grounding is crucial
    Power the pda off the pc or dc-dc or what ever you end up with.
    What is the output voltage of the palm wall wart?
    Nov 2006
    Snellville, GA
    On the transformer:
    Input: 120VAC 20 HZ 0.1A
    Output: 4.1 VDC 0.4A
    .......... 6.0 VDC 0.1A
    That's all I know about the power requirements. I'm not really sure how I would power that. 12Watts of electricity is nothing . Say i did a DC-DC power supply. Should I :
    a) cut off the end of one of those cheap 50W cigarette lighter inverters and hardware it with an inline fuse or spliced in
    b) wire it to the computer?? how? dc-ac or some other modification?
    c) a bigger inverter?
    i'll keep searching, but i would greatly appreciate any help.
  1. VW Golf Stock head unit to PDA via CD Changer Port??
    By TheMiddle in forum General Hardware Discussion
    Last Post: 07-17-2009, 03:50 PM
  2. pda for datalogging & mp3 files?
    By kgj in forum Input Devices
    Last Post: 05-15-2006, 03:15 PM
  3. WOL and Remote Control by PDA
    By NOS TANG in forum Wireless Communications
    Last Post: 01-08-2005, 04:44 PM
