Results 1 to 6 of 6
Thread: Headrest monitor input question
    Low Bitrate hypnotiq's Avatar
    Aug 2005
    Hey,
    I plan on using a laptop for my carpc with a xenarc 7000tsv screen. I was wondering if i got headrest monitors how would i get video to them?
    Elsewhere
    How about the Wiki?
    Aug 2005
    I'm sorry i still don't understand, let me try to clarify my position.
    I have a dell 600m as my carputer that connects through vga to my xenarc 7000tsv. I'm trying to get that same video feed into a headrest monitor. However, the headrest monitor accepts only rca video input, and thus my dilemna.
    thanks
    Elsewhere
    Ahhh.
    You need some device to clone the signal, I believe.
    How about the Wiki?
    Aug 2005
    I have s-video on my laptop; i think i can use it to convert to rca. My other question would be how many times would i be able to split the signal before it would be not very clear?
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    All you need is a cord that has the 4 pin s-video on one end, and the rca on the other. I picked one up from what used to be radio shack up here canada. then you just set it in the displays section to clone the desktop from your primary monitor.
    Keep in mind that if you do more than 2 monitors on the same, you will most likely need a video amplifier, you can get one from www.MP3playerstore.com
    Here a pic of my set up to give you an idea.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  3. Replies: 9
    Last Post: 03-28-2005, 12:26 AM
  4. Please answer question on headrest displays
    By Rafster in forum LCD/Display
    Last Post: 10-09-2003, 08:21 PM
  5. question about ripping apart lcd screen
    By FALLENNITE in forum LCD/Display
    Last Post: 01-21-2003, 07:55 PM
