I don't think you want to hook your antenna up to the rear defroster. Just sounds like a bad idea.
I was doing some searching on the forums and came across the fact that I some have connected their antenna to the hauppage usb tvtuner to get radio. How good is this sound quality? My lexus es300 uses the entire rear defroster which doubles as an antenna so I'm hoping it gets good signal but wanted to inquire to those that have done it already.
Also, if I use a hauppage tv tuner.. can I control the stations by road runner? and if so how? I did some searching but I think i'm searching the wrong keywords or something.
thanks in advance.
.s.
Cars:
2001 Lexus es300 carpc Complete!Lexus es300 thread
CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
2006 Lexus es330 next project.
Failure is not an option....
It's installed by default on every version of Windows.
All Lexus 2001 es 300's are already wired this way. The defroster doubles as an antenna which is why you dont see those cars with a sharkfin or antenna.
Cars:
You have the same Q as me... i'm investigating a USB radio device for my car...
spiike, are you certain that the defroster "doubles" as an antenna? its very possible the the antenna is imbedded in the window glass, but not very likely it is the same unit as the actual defroster grid. just something you might want to be certain of.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
You may be right. Technical term is lexus FM diversity antenna. I would take a picture but my tints will not show the antenna well. It's embedded in the glass and the sales person had said it was same as the defroster, which is where I got the idea from.
Cars:
got the same setup in the rear glass, i use happauge usb, fm no problems connected. works good just need a fm amp imo.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
yes signal booster to increase fm signal.
yes sit between antenna and the usb receiver.
yes it is a powered device, runs off of 12v.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Does the Tv Tuner portion of it work okay?
