Results 1 to 6 of 6
Thread: any way to keep s-wheel controls w/o IR?
    Jul 2004
    Santa Barbara, CA
    Question any way to keep s-wheel controls w/o IR?
    Hey guys, i've been reading around here, and i've discovered that my '02 Camaro has the type of steering wheel controls that changes the resistance depending on which button is pressed. So i've read that i can use the PAC SWI and an IR remote to control my system.
    I'm wondering if theres a way to run the SWI directly into the serial port, or something like it. It seems like an IR remote would be a weak point in the hookup, and i've got a pretty stiff suspension...
    Also, which version of the SWI would i need to run?
    Here's the page w/ 'em all:
    http://www.pac-audio.com/products/pr...el%20Interface
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    i bet you can run it direclt to the serial port... no, i garentee it.
    but i doubt the programs are out there for you to do it, so you would ahve to program it yerself
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Jun 2005
    Whats wrong with using IR control via the PAC SWI-X? What the heck does suspension firmness have to do with it? I cannot even imagine how a bumpy ride would have any effect whatsoever on IR reception. From a cost standpoint IR control is really pretty hard to beat:
    PAC SWI-X $60
    USB-UIRT $60
    AIVMS Software $15
    Newbie altinono's Avatar
    Jan 2007
    hi
    i don't know if u mean u can use the IR receiver and remote control
    my ENGLISH IS BAAAAAAAAD
    but u can use the remote control as the keyboard
    but this depend on how many button in the remote control
    and u can use it as mouse
    it's cost nothing
    all what u have to do is building a LIRC receiver
    it's very simple
    and use MiriServer program with winlirc program
    u can choose any function in the keyboard or mouse to be in the
    remote control
    Jun 2005
    Well, you are on the right track as far as needing an IR reciever on the PC is concerned. That still leaves getting the steering wheel controls into a format that the PC can read (an IR signal in this case) which is what the PAC SWI-X does. You could potentially build your own circuits for your entire car-pc, but that does not mean it is feasible. A device such as the USB-UIRT represents a very refined commercial grade IR transceiver, and IMO it is well worth the money. The software you choose to interpret the IR signals and produce the desired action can obviously vary, but both Girder and WinLirc are much harder to use than AIVMS is for this purpose.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Car buttons
    I think this works too. I haven't used one but I think that is what it is designed for.
    http://www.madhacker.org/carbuttons.htm
  1. Steering Wheel ADD-ON Controls w/o System
    By ChaCha in forum General Hardware Discussion
    Last Post: 05-21-2009, 11:22 PM
  2. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
  3. Replies: 1
    Last Post: 01-05-2006, 10:38 PM
  4. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 05:27 AM
  5. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:20 PM
