Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 71
Thread: Inside the space navigator
  1. #51
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    Quote Originally Posted by booksix View Post
    Bringing this thread back up... Saw there was some progress on isolating the axis'... can this unit be used like the iDrive except where pushing/tilting the knob would replace the four buttons?
    I've written some software with some help from others on the boards here. It basically intercepts the inputs from the space navigator, and will perform various actions based on the input, including gestures. Check my sig for a download link.
    It's actually fairly sophisticated, but it's complex to configure and consequently not many people have adopted it. It got a bit sidelined since I adapted it to take mouse input as the result of another consulting gig I was working which required mouse input (gestures mostly) to trigger actions as a proof of concept.
    I do have a config utility, which I haven't really completely banged out, but should upload and document it a bit better.
    Sadly, I'm currently busy with another consulting gig, so it may be a bit longer before I can get back focused on this, but I'll be certain to try again soon.
    For perspective, I STILL haven't gotten this thing installed in my truck with the rest of my carpc.
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
  2. #52
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    well Mike (Malcom2073) hooked me up with an led swap from the factory blue to red. I did not have to dye or sand the blue ring to come up with this result...
    Live mp3Car Facebook Chat
  3. #53
    May 2008
    That looks really good. I wouldn't mind changing the color on mine. Can you pass along any tips or part numbers?
    Hans
  4. #54
    Low Bitrate aziodale's Avatar
    Jun 2009
    Italy Sicily Palermo
    Quote Originally Posted by Sonicxtacy02 View Post
    May i know how much is diameter in centimeters for fix space navigator?
    is fixed without metallic part below?
  5. #55
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by hans14914 View Post
    Hans
    you'll need at least 6 smd 463 leds.. should probably be rectangular shaped. I would SINCERELY recommend getting at least 10 though.. they are extremely small and easily get lost. Only other things you need are a high power soldering iron, a thin tip, and a very steady hand.
    Quote Originally Posted by aziodale View Post
    i dont know the diameter unfortunately. In my case the metal base has been removed and the space navigator sits in a hole with hot glue underneath
  6. #56
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    That was one of the more difficult things I've had to solder, so definitely get at least 10. Just the slightest bit of static electricity is enough to make them go fly across the table. (Or in my case, the hood of a car)
    RevFE
    My Shop
  7. #57
    Jun 2009
    Without the metal part of the space needed (the hole) is less?
  8. #58
    Woodbridge, VA
    Blog Entries
    55
    yes.. the base is nothing more than a weighted bottom. Removing it makes the diameter and height smaller.
  9. #59
    Jun 2009
    Hi
    I hope you help me in a strange problem:
    Space navigator with RBC9 function perfectly but if i start carpc o resume it from ibernation with Space Navigator connected Centrafuse stops working.
    When stop after booting lock centrafuse on Initializating controls....
    after ibernation black screen :-(
    What you can suggest to resolve?
  10. #60
    Jun 2009
    uppete
  1. Underwear Goes Inside The Pants
    By RedGTiVR6 in forum Off Topic
    Last Post: 03-18-2007, 11:00 PM
  2. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
  3. Heat dissipation inside dash or other enclosed spaces?
    By Arathranar in forum Power Supplies
    Last Post: 02-01-2005, 05:32 AM
  4. A Questions To The Mods ( Space )
    By ccsnet in forum General MP3Car Discussion
    Last Post: 06-06-2004, 01:55 PM
  5. Win95 Network drive free space?
    By Bj in forum Software & Software Development
    Last Post: 04-02-2001, 10:40 PM
