Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Ford Radio Rotary Encoder via PS/2 Mouse
  1. #11
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Mouse encoder signals don't give a forward and a reverse. There are just two lines that pulse when the encoder sees light or dark. Direction is determined by which of the two signal lines occurs first when rotating.
    ~Jimmy
  2. #12
    Low Bitrate spudgunblunder's Avatar
    Aug 2005
    0-0-7, Here's a simple pinout:
    BEFORE
    AFTER
    Thanks Jimmy.
  3. #13
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    USB volume knob
    I was recently experimenting with mouse rotary encoder too. Made rough sample:
    The knob made of VHS head.
    There is a program called autohotkey. It alows to map hotkeys to wheelUP/DOWN, buttons.
  4. #14
    Aug 2005
    I like the look and the smoothness would be great. How do you have AutoHotkey setup? (post your script here) I'm using it already but want to know how to do THIS.
  5. #15
    Oct 2006
    Lisburn
    Hi. was'nt playing alot with autohotkeys. what about someting like that
    wheelUP::F11
    wheelDOWN:F12
    Lbutton+wheelUP::(assign for scrool up)
    Lbutton+whelDOWN::(assign for scrool down)
    Rbutton+wheelUP::(assign zoom in)
    Rbutton+wheelDOWN::(assign zoom out)
    I actualy meade hotkeys just for volume.
    i wander if u can buy those encoders in shop separatly.
    Cheers
  6. #16
    Aug 2005
    That would be the best alternative but I'm not sure how to go about it. I'm using a touch screen so I can't use the left mouse button can I? If I connect a push-stay on switch to the right button it only gives 2 options.
    Thanks for the suggestion tho agniusm.
  7. #17
    Oct 2006
    Lisburn
    I would say that if you remap your mouse buttons they will not acts as mouse buttons anymore. Give it a o and see what happens. Cheers
  8. #18
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by spudgunblunder View Post
    BEFORE
    AFTER
    Thanks Jimmy.
    I've been hacking apart my dash and plan on doing this method too for volume control however I find a slight fault with your wording and I don't want it to cause problems for others.
    Instead of saying "GND" I would use the word "Common". The reason I say this is that I checked a PS/2 mouse and found the what you ahve label "GND" actually is reading 5V with a multimeter. If someone were to hook this up to GND you might kill your USB ports or PS/2 connection.
  9. #19
    Aug 2005
    Well spotted durwood.
    Thanks.
  1. PS2 3 Button(Rotary Wheel) Mouse Properties?
    By nFiniteTuning in forum Input Devices
    Last Post: 03-12-2005, 09:43 PM
  2. USB FM Radio( + mouse ). Not kidding !
    By jbors in forum Input Devices
    Last Post: 03-11-2005, 05:46 PM
  3. MECI PS/2 Trackpoint Stick Mouse Review/INFO
    By spectrrr in forum Input Devices
    Last Post: 05-14-2004, 07:08 PM
  4. Replies: 3
    Last Post: 01-19-2004, 06:15 PM
  5. PS/2 mouse keyboard plugs
    By cproaudio in forum General Hardware Discussion
    Last Post: 11-10-2002, 05:55 AM
