Results 1 to 7 of 7
Thread: Cameras and IR illumination
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    Hi folks. I have bought 1.3mp usb webcam. Now im looking for sort of IR illumination but stuck. Usual LED's i think will not provide enough illumination, basicaly will be limited to 50m or so i think with huge IR lamp. Perhaps i'm wrong. Now those new 7 class BMW.
    I found these LED's: http://uk.farnell.com/jsp/search2/br...questid=688798
    The new BMW: http://www.youtube.com/watch?v=-3uaTyNWcBI
    Does anyone know indeep about night vision, IR illumination etc.? Some information will be much appreciated, Thanx
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    search!!! look for night vision
    Mar 2005
    NY
    if you need IR leds, i know nitemaxmax has some spares from his cameras. These are 15 LED arrays and they're top notch. But yeah, search. any Nitemax thread is just chalk full of information and people toying with it.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Oct 2006
    Lisburn
    Search is what i do first cause most i like to figure out things myself. Now i have CCD CCTV night cam with LED array but the image is crap at night. I figured that the BMW is using a thermal camera not som kind IR illumination,thats why the image is good but the price is good to. Anyway will see those Nitemax
    Cheers
    Mar 2005
    NY
    yeah, that's definitely thermal. IR will allow you to see anything, hot or cold, clearly. Thermal just hot. Its good for spotting mammals. but not as adept as seeing other things in detail
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Dec 2006
    IRritation, IRradiation, and noctural emmitters
    Quote Originally Posted by agniusm View Post
    ...Usual LED's i think will not provide enough illumination, basicaly will be limited to 50m or so i think with huge IR lamp.
    Tough question. We use IR emmiters that provide about 175M with the highly sensitive cams we use. These emmitters paint about a 30M scene 130M out. Mostly for lights-out crawling at night, not effective above about 40KPH re stopping distance. The units are flat panels about 40x40, but I if you're looking for throw, you may have to install a set or more of IR "fog" lamps with reflectors designed for long IR wave and plenty of input wattage. Low end on these tend to be highly red-filtered halogens. There may be a gas discharge type lamp that's IR - Phillips or Bosch are probably the best sources.
    Considering the rapidly dropping consumer cost for night-vision and the move away from active emmiters by MOD, you might get older but highly useful military surplus cheap.
    Cheers.
    Oct 2006
    Lisburn
    Cheers.
    Thanx for the info. Im not an expert, but i like to make things my self cause it gives me alot of joy. I found some stuff and i would like your opinion im3crazy
    those are IR emitters:
    http://www.epigap-berlin.com/index.php?id=40&L=1
    the ELJ-870-629 and ELJ-940-629
    http://www.roithner-laser.com/LED_HP_multi_chip.html
    LED870-66-60 and the last one:
    http://uk.farnell.com/jsp/endecaSear...ZQ?SKU=1242051
    SFH4230
    What do you think about using these for illumination?
    They are with different wavelength. what wavelength is best for illumination?
    I would like to build some kind o array to fit as foglights.
    Thanx again
  1. Night Vision (IR) cameras
    By e_fractal in forum Input Devices
    Last Post: 10-30-2007, 06:22 AM
  2. How to test your LCD IR Remote
    By Quack in forum LCD/Display
    Last Post: 03-14-2006, 02:57 PM
  3. Cameras, Rearview, Infrared and such
    By guardianzx9 in forum General MP3Car Discussion
    Last Post: 02-07-2006, 12:13 PM
  4. IR vs Thermal
    By Juliemac in forum Input Devices
    Last Post: 10-02-2005, 11:28 PM
  5. reverse cameras
    By dexy in forum LCD/Display
    Last Post: 05-24-2005, 04:45 PM
